Want to cam - Mustang Evolution
Old 07-14-2012, 10:37 PM   #1
Foxbody Nate's Avatar
Want to cam
Hey guys I need some help I have a 88 gt all stock besides exhast. I want to put a b303 cam in the car has 109k org miles what do I need to do to cAm it any upgrades?
Foxbody Nate is offline   Reply With Quote
Old 07-14-2012, 11:40 PM   #2
Dont do a B cam, do a E cam
fast 94 5.0 is offline   Reply With Quote
Old 07-15-2012, 12:41 AM   #3
I don't know how crazy I can go be a speed density car and stock motor
Old 07-15-2012, 05:52 AM   #4
Forum Car Trader
90GTNovi2000's Avatar
I disagree the b cam will work fine with your setup. The E is a bit more aggressive.. I have a lil b cam in my 90' and it's a beast. I have a lil clip for an example of the sound. Minus supercharger.
90GTNovi2000 is offline   Reply With Quote
Old 07-15-2012, 06:14 AM   #5
Re: Want to cam
You can't do much of anything for a cam until you convert it to MAF.
Any mod that will affect the air flow will mess with the speed density.
And, putting just a cam in a stock engine that hasn't been modified to take advantage of the increased air flow is a waste of time and money.
Save your money, convert to MAF, then do HCI all at once.
Trick Flow has an HCI kit that will net you around 360 HP.
Old 07-15-2012, 06:26 AM   #6
Forum Car Trader
+1. You gotta loose the speed density junk,.. Then maybe a small cam. But if you can save what TH said is the best bang for your $$
Old 07-16-2012, 12:19 AM   #7
Is everything I need for mass air in this kit???
http://item.mobileweb.ebay.com/viewi...id=02082706046
Let me know ASAP if anyone knows or have bought this too!
Thanks
Old 07-16-2012, 02:42 AM   #8
Re: Want to cam
Thanks
It appears to be complete.
You might want to ask if the O2 sensor harness is included.
Backyard Conversion
Old 07-16-2012, 07:29 AM   #9
What's the difference between the computers being a9l.,a9p,8ld I have a 88 gt automatic witch one do I need??
Old 07-16-2012, 07:37 AM   #10
Forum Car Trader
I believe you need the a9l
Old 07-16-2012, 07:39 AM   #11
Finchms's Avatar
A9l is for a 5spd., a9p is for the auto and can be used on a 5spd., and 8ld is a cali-5spd
Finchms is offline   Reply With Quote
Old 07-16-2012, 09:22 AM   #12
So I need the a9p ???
Old 07-16-2012, 09:49 AM   #13
Forum Car Trader
I would see what TH says.
Old 07-16-2012, 10:21 AM   #14
kickerofdoom's Avatar
How hard is it to cam a old 5.0?
Old 07-16-2012, 10:24 AM   #15
Forum Car Trader
Depends on who your asking.. I've seen guys do a swap in a Hr.. On carb cars. 2 on EFI
---------- Post added at 11:24 AM ---------- Previous post was at 11:23 AM ----------
And I've seen many problems pop up along the way you have to be prepared for.. So allow a wknd of work if you plan on doing it.
Old 07-16-2012, 10:27 AM   #16
Yeah i always try to plan ahead. O by the way anyone get the foxbody mustang magazine/
Old 07-16-2012, 10:59 AM   #17
Re: Want to cam
Yes that will work. The "tune is a bit more aggressive for the A9L, but the A9P is tuned to be suitable for the AOD to keep from damaging it.
How old?
Old 07-16-2012, 11:03 AM   #18
How old?[/QUOTE]
A 87 gt
Old 07-16-2012, 11:04 AM   #19
Re: Want to cam
Nope, I tried to talk with them about a subscription a while back and got a snarky, smart aleck answer, so I for one am not interested in their magazine.
Old 07-16-2012, 11:05 AM   #20
Re: Want to cam
How old?
A 87 gt
The first thing you will need to do is to convert it to MAF.
The speed density system throws a fit whenever you mess with anything that changes the air flow.
Old 07-16-2012, 01:21 PM   #21
93slowstang's Avatar
Figured i'd correct this real quick, the a9p is the more aggressively tuned out of the 2. The a9l pulls timing between shifts, not the a9p.
Old 07-16-2012, 02:13 PM   #22
Re: Want to cam
I certainly got that bassackwards didn't I?
Here's some info I found.
I cannot vouch for its accuracy though, so use it at your own risk.
A9L
RPM_____0____0____1,000___1,800___2,150___2,600___3,500___5,000
Degrees___8____8_____8______18.5____21.5____22.5_____22______25
A9P
RPM______0____0____0______1,600___2,250____2,600___3,500___5,000
Degrees___18____18____18_____18______22______23______22______26
X3Z
"You can put an automatic ECM in a manual car, but not vise-versa, unless you deal with the trans switch situation mentioned below. You must cut the wire leading to pin 30 on the 60 pin ECM connector if you are installing a manual trans ECM (like a A9L) in an automatic car. If not, you will burn up the ECM."
Old 07-16-2012, 02:17 PM   #23
Well we can blame the meds.
Old 07-16-2012, 02:28 PM   #24
Re: Want to cam
Sometimes, but I think this one is just one I got confused about.
Thanks for watching out.
Old 07-16-2012, 03:36 PM   #25
Always.
Old 07-16-2012, 11:03 PM   #26
So witch one do I need for a 88 gt stock aod??
Old 07-17-2012, 04:32 AM   #27
The a9p.
10:20 AM
