Going Crazy!!!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 07-16-2012, 06:49 PM   #1
Foxtrot's Avatar
Foxtrot is unknown around these parts
Going Crazy!!!!
Well in the process of putting on my American thunder exhaust on my 1992 gt and have run into a problem. I put the passenger side in just fine, but I can not get the tail pipe over the rear axle on the drivers side. Do I have to drop the axle or something?!?
Foxtrot is offline
Old 07-16-2012, 07:06 PM   #2
Pete Jones
90mustangLX's Avatar
90mustangLX is unknown around these parts
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Did you jack up the body and let the axle droop?
You may also need to remove the lower shock bolt, pull the shock back out of the way to let the axle droop a little farther but be careful not to pop te coil spring out.
90 LX 5spd swap Stock 302 GT40P heads
BBK shorties and h-pipe
flowmaster 40's dumped, Jegs Big n Littles
BBK CAI, BBK SSI-R upper and lower
Professional Products 75mm TB,Electric Fan
MSD 8.5 90 degree plug wires
90mustangLX is offline
Old 07-16-2012, 07:19 PM   #3
Foxtrot's Avatar
I'll try that I was jacking it up on the axle didn't have alot of time to try that so I will try that tomorrow. Thanks for the tip
Foxtrot is offline
Old 07-17-2012, 10:47 AM   #4
Foxtrot's Avatar
It worked thanks for the tip now just gotta get here running again and well be tearing up the strips!
Foxtrot is offline
Old 07-17-2012, 11:17 AM   #5
Pete Jones
No problem, glad it worked
Closed Thread
10:14 PM
