93 lx long tube headers problems - Mustang Evolution
Old 07-17-2012, 09:48 PM   #1
93_347foxbody's Avatar
I bought a set of longtubes from summit for a 93 lx 5.0. Is there less room under there on models originally auto 4 cylinders. Bc my header won't fit right. I completely took the steering linkage out and the motor mount and the valve cover off and I can get it mostly to fit but its hitting either the bell housing or the firewall depending on what angle I move it and it won't move any other way. I tried jacking the motor up and even lowering it a bit but I can't get it to fit still. Anybody put summit longtubes on before or any other longtubes and had run into these problems? Idk why they don't fit. I know for a fact I checked and it said they fit a 93 lx 5.0. Please help lol
93_347foxbody is offline   Reply With Quote
Old 07-17-2012, 10:02 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
Oh yeah your not the first!!! A hammer is about to become your friend lol it needs a lil massaging to fit. Be patient I think dream had this problem he will respond shortly.
90GTNovi2000 is offline   Reply With Quote
Old 07-17-2012, 10:05 PM   #3
I was using a rubber mallet for a bit. Would it be easier going from underneath bc I was gonna out it up on ramps and try. I didn't even attempt the pass side yet lol
Old 07-17-2012, 10:12 PM   #4
Forum Car Trader
Passenger side should be easier.. But yes definitely try from the bottom up.. Jack the body of your car up for some clearance. Not the chassis.
Old 07-17-2012, 10:22 PM   #5
I did jack the body up at first but its hitting the bell housing and firewall it kinda looks as if the last two cylinders, the header goes too far back
Old 07-17-2012, 10:34 PM   #6
Forum Car Trader
Ok.. Well give a lil bit for the gang someone has done it... I have once but the motor was already out so we were able to move it with the hoist.
Old 07-17-2012, 10:42 PM   #7
Lol I wish I can just take the motor out and do it. And also I just double checked and the header on summit for the 93 lx 5.0 is identical so I know I didn't accidentally buy a different 5.0 mustang headers lol
Old 07-18-2012, 04:36 AM   #8
I only have the summit shorties. But the fitment was great. I didn't take anything off whatsoever, they basically slid into place. But yeah I know long tubes are different.
They gotta fit on there. Longtubes are a pain in the butt all the time. When 90 says massage, you may have to actually dimple the tube for clearance.
Old 07-19-2012, 07:28 AM   #9
Still can't get them on :/ spent the last 2 days just trying to fit the driver side I tried almost everything
Old 07-19-2012, 07:31 AM   #10
Maybe you can take some pics and we can give you some ideas?
What's it hitting? The bellhousing still?
Old 07-19-2012, 12:56 PM   #11
Yeah bell housing and I think its the k member Idk. I'll go get some pics now
Old 07-19-2012, 02:38 PM   #12
It doesn't fit in between the bell housing and I believe the k member I think if that's it and the cable down there. I jacked the motor up as high as I could took the motor mount off took the steering linkage or whatever out and it won't fit. I tried angling it every possible way
Old 07-19-2012, 02:39 PM   #13
I took the header out bc you couldn't really see it with it in there my camera wouldnt take a good pic of it
Old 07-19-2012, 02:45 PM   #14
Hmmm... It's really hard to tell from the pic. But unless because mine is a convertible, it looks way different. Do you have an aftermarket k member?
Old 07-19-2012, 03:42 PM   #15
I wasn't told so. Maybe. I know the entire front suspension isn't from the lx. Idk if the k member is included when he said that
Old 07-19-2012, 05:38 PM   #16
Forum Car Trader
Ok undo your motor mounts and jack the front of the motor up at the balancer then slide them in from the bottom. Place wood blocks on top of jack so u don't hurt the pulley
Old 07-19-2012, 05:40 PM   #17
does that look like the stock k member? its different from mine, but i didnt know if thats because i have a vert?
Old 07-19-2012, 06:03 PM   #18
Forum Car Trader
It's hard to tell from the view I can't see much of it but it doesn't look tubular. So my guess is it's stock
Old 07-19-2012, 06:15 PM   #19
Re: 93 lx long tube headers problems
Pull those plugs out and stuff some paper towel or rag into the holes, otherwise you stand a good chance of breaking them.
Old 07-19-2012, 06:17 PM   #20
imthink i was looking at the pic wrong lol. its hard to see. but i say your technique may work.
Old 07-19-2012, 06:30 PM   #21
Forum Car Trader
I searched the problem on google and found it in another forum and several agreed that was the only way.
Old 07-20-2012, 11:23 AM   #22
Good researching.
Lifting the car and engine is the only way to install some long tube headers.
Old 07-20-2012, 10:10 PM   #23
I did take the plugs out after. I couldn't try today bc its been pouring but as of now still no luck. I might just put my shortys back on and bend some tubing to fit to the shorty catted h pipe I'm gonna wait till school starts to put it on the lift in my shop its only a month to wait. I don't wanna keep trying bc I wanna drive it lol. And I only have basic tools here
08:13 PM
