How can I check if I have the correct size pushrods? - Mustang Evolution
Closed Thread
Old 07-18-2012, 06:18 AM   #1
Ford Block
Stroker kit
stock heads
stock rockers
stock push rods
JayKranz is offline
Old 07-18-2012, 06:40 AM   #2
Forum Car Trader
90GTNovi2000's Avatar
You can rent or borrow a pushrod length finder from a auto part store.. Google it they are simple to use..
90GTNovi2000 is offline
Old 07-18-2012, 07:50 AM   #3
Yeah, best way
They are only 10$ from kegs or summit.
dreamstang is offline
Old 07-18-2012, 07:51 AM   #4
Forum Car Trader
Kegs lol
Old 07-18-2012, 07:56 AM   #5
I love a nice cold Keg!
JayKranz is offline
Old 07-18-2012, 07:57 AM   #6
Lol. Oops
Old 07-18-2012, 09:26 AM   #7
Re: How can I check if I have the correct size pushrods?
Originally Posted by dreamstang View Post
Lol. Oops
Me too, but they sure make working on your Mustang difficult though.
Trojan Horse is offline
Old 07-18-2012, 09:45 AM   #8
I just ordered the length checker. We shall see! I just don't want to do anything else until all this stuff is checked out. Also, is it possible this lunati cam is too much?
Camshaft Specifications Intake Exhaust
Advertised Duration (degrees) 276 280
Duration @ 0.050” (degrees 221 223
Valve Lift (inches) 0.509 0.509
Lobe Separation Angle (degrees) 112
Opens (degrees) 3.5 BTDC 48.5 BBDC
Closes (degrees) 37.5 ABDC -5.5 ATDC
Also, the pushrods that came with this Holley kit(I do not have the kit I only have the cam) were 6.40 inches vs. my stock 6.25 inch rods. Any thoughts?
JayKranz is offline
Old 07-18-2012, 11:46 AM   #9
I doubt it is to much. If you enter your engine specs on CamQuest, you can see what they recommend and compare the specs.
If they sent those pushrods with the kit and you are using the cam that came with the kit, then they should work.
Old 07-18-2012, 12:24 PM   #10
I am using my stock pushrods
JayKranz is offline
Old 07-18-2012, 08:26 PM   #11
Any time you make a cam or head change you might need to change the pushrods, so it's best to check them.
Old 07-18-2012, 08:28 PM   #12
I ordered the comp cams push rod checker today.
JayKranz is offline
Old 07-19-2012, 04:08 PM   #13
Got my comp cams push rid checker. Seems like it has confirmed that my stock length pushrods are good. I suppose I can rule that out then. New oil pump, new pcv, new everything except heads. If one of my heads was cracked could it cause the oil to go in to my upper intake?
JayKranz is offline
Old 07-19-2012, 06:05 PM   #14
I guess it could if you had some reverse flow happening from cam overlap or something, but normally it would be confined to the head and cylinder.
Old 07-19-2012, 06:06 PM   #15
Okay, O just put a video of the motor running in a new thread.
JayKranz is offline
Closed Thread
05:28 PM
