Stuck Brake Caliper - Mustang Evolution
Old 07-18-2012, 08:44 AM   #1
deadsp0t's Avatar
Stuck Brake Caliper
Ok, so did a search and couldn't find any threads that had been followed up with a solution.
Yesterday I hear the right rear brakes grinding, so I pick up the pads and go to change them and the inside pad is trashed, the clips were almost ruined. I can't get the piston to compress almost at all, bleeder valve is open and some fluid came out but not what you'd expect. I have jacked up the threads on two caliper spreaders and am now at a loss what to do..
Am I stuck buying a caliper at this point? Or is there something I'm missing? Car has ABS brake BTW...
That's unimpressive
Old 07-18-2012, 08:47 AM   #2
Meansaleen's Avatar
You need to buy a new caliper. It seized
Meansaleen is offline   Reply With Quote
Old 07-18-2012, 08:54 AM   #3
deadsp0t's Avatar
Figures..
I've never had issues like this with brakes before!!
Idk that I've ever bled brakes on anything but my bikes, much less opened a bleeder valve to spread a caliper!
That's unimpressive
Old 07-18-2012, 09:30 AM   #4
Meansaleen's Avatar
Originally Posted by deadsp0t
Figures..
I usually don't open bleeder. I take a square piece of steel just a bit bigger than piston and I compress piston with a c clamp. Usually don't need to bleed brakes if I do it that way.
Old 07-18-2012, 09:33 AM   #5
deadsp0t's Avatar
Similar here! That's why this was aggravating! Plus it's almost 100* outside lol
After 8 years in an air conditioned factory in AC spoiled
That's unimpressive
Old 07-18-2012, 10:09 AM   #6
It's not me, it's you.
primer2tone's Avatar
If you've got access to an air compressor you can remove the bleeder and using an air nozzle with a rubber tip you can blow the piston out. Hone out the piston chamber and replace the seals for just a few bucks. Even if you decide to just buy a new caliper be sure to replace all the hardware too! And remember, grease is your friend, just don't rub it on the brake pads. Lol
In the past if I couldn't collapse the piston using an old brake pad and a big pair of channel locks, I'd pull the caliper and rebuild it.
Old 07-18-2012, 10:16 AM   #7
wereKEV's Avatar
Re: Stuck Brake Caliper
There are some calipers that need a special tool to compress them because they have to turn and compress at the same time,but I don't know if your year has those calipers my 98gt had them.
wereKEV is offline   Reply With Quote
Old 07-18-2012, 10:16 AM   #8
DaBluedude's Avatar
You can probably rebuild the caliper but it might be cheeper/safer to buy a replacement. Those rear calipers are fairly cheap.
2003 Mach 1
Old 07-18-2012, 10:22 AM   #9
vinnygt's Avatar
Just replace it. It will be much less stressful in the end. My friend had this same problem but on both sides in the rear. He tried and tired to fix it and eventually he just warped his rotors. And he still ended up replacing the calipers anyway (and obviously rotors).
vinnygt is offline   Reply With Quote
Old 07-18-2012, 10:32 AM   #10
deadsp0t's Avatar
Thanks for the quick replies and knowledge!! Believe I'm going to just replace cause my wife uses the car as much as I do and often has my daughter with her! I'll take some pics and update the out come for future searches!! Thanks again ppls!!!
That's unimpressive
Old 07-18-2012, 10:35 AM   #11
Good luck man! And if you need anything, here's some ants...Click image for larger version
Old 07-18-2012, 10:38 AM   #12
deadsp0t's Avatar
Word!!! They will do my bidding!!!!
That's unimpressive
Old 07-19-2012, 09:38 AM   #13
deadsp0t's Avatar
Ok so apparently REAR disc brake require a disc brake master kit tool to compress the piston. It actually spins the piston into the caliper which is why I ruined my caliper spreaders!!! Cost $100 bucks to rent the kit but I got all of it back when I was done! Rented at Advance Auto. Here are pics..
ID:	59751   Click image for larger version
That's unimpressive
Old 07-19-2012, 09:50 AM   #14
Yeah. Sorry I thought someone had mentioned that or I would have said something. My very first time on rears like that I ruined a c clamp. But I can usually get away with using channel locks.
Old 07-19-2012, 09:53 AM   #15
deadsp0t's Avatar
Looking back, Kev mentioned it lol
On my old 95 I didn't need a tool that I remember!?
Maybe cause it was a GTS and didn't have ABS?!
That's unimpressive
Old 07-20-2012, 12:13 AM   #16
DaBluedude's Avatar
The 95s are the same. I assumed u knew. Based on your number of posts haha. Those kits are worth their weight in gold. Fyi, harbor freight sells the same kit for 21$ if I remember right. Im gonna get one because my city only has 2 of them and last time I got lucky. Next time? They also sell these little steel blocks which can easily be modified to do it. But they're a lot harder to use.
2003 Mach 1
Old 07-20-2012, 12:28 AM   #17
deadsp0t's Avatar
Swear I didn't need it on my old car, although I could be wrong I guess.. I know when I searched e1 said they bought a new caliper too..
They had the block but none of the tabs were even close(checked against the kit and a new caliper).
Oh well maybe my mistake will help someone else out one day.
That's unimpressive
Old 07-20-2012, 08:29 AM   #18
DaBluedude's Avatar
Yeah, those little blocks have to be.modified. I used a little dremel to cut 2 of the pegs off the one side then it fits perfect. But that kit is worth its weight in gold. Way easier and those pistons are actually pretty soft metal and the cubes slip easy damaging the piston. Glad you got it sorted!
2003 Mach 1
05:43 AM
