power loss??? - Mustang Evolution
Old 07-18-2012, 12:36 PM   #1
foxbox's Avatar
power loss???
Okay I have a 92 hatchback , finally restored with mostly stock 302 except long tubes and cold air. It is a 5 speed. Electric fan and the removal of air pump equip. I notice that the car has a hesitiation when im climbing 2000 to 3500 rpms. It feels like something is holding it back. Also has had tune up so new plugs, wires, and fuel filter. Anyone have any ideas?
foxbox is offline   Reply With Quote
Old 07-18-2012, 04:13 PM   #2
Sounds like a coil or distributor issue. You can test these parts to be sure.
Old 07-18-2012, 09:05 PM   #3
foxbox's Avatar
Thank you, I forgot to mention I have a rather new accel super coil. Ill check the distributor though, do you think a bad sensor such as tps could cause this problem?
Old 07-18-2012, 09:11 PM   #4
itsmpossible but probably not the tps. you can test the voltage to be sure. also wouldnt hurt to check fuel pressure and timing.
Old 07-18-2012, 11:43 PM   #5
Re: power loss???
Timing issue possibly.Did you set the timing correctly and replace the spout connector when finished?
Old 07-20-2012, 12:22 AM   #6
foxbox's Avatar
Okay ill check it out, busy with work
for next few days though. I managed to replaced header gasket today...nothing worse than an exhaust leak to ruin the sound of a mustang!!!
12:35 AM
