No power. - Mustang Evolution
Closed Thread
Old 07-18-2012, 03:58 PM   #1
Thrasher13's Avatar
No power.
Recently rebuild the motor in my 89 hatch. All I did was freshen it up and put some gt40p heads on. Now I have no power at all. And it revs so slow. It's also sounds a little like a tractor when you first start revving. It's almost skipping but it's not. It's like a cylinder isn't firing but yet at idle the sound is good. It also is randomly after firing. It can be idling fine and all of a sudden pop then back to normal.
Thrasher13 is offline
Old 07-18-2012, 04:11 PM   #2
I would check fuel pressure and timing.
Then you may want to check spark at each cylinder to I sure they are all firing.
dreamstang is offline
Old 07-18-2012, 04:48 PM   #3
Thrasher13's Avatar
I've played with my timing. I set it at 36 base timing at 2k. And it after fired bad. So I've been slowly retarding it. And it's still doing it at 16
Old 07-18-2012, 04:51 PM   #4
Unplug the spout connector and set it to 10* at idle.
Old 07-18-2012, 04:57 PM   #5
Thrasher13's Avatar
Il try that. And get back to you. Thanks
Old 07-18-2012, 04:59 PM   #6
No problem
---------- Post added at 05:59 PM ---------- Previous post was at 05:57 PM ----------
Also unplug the spout with car off. Then plug it back in after you set timing with car off
Old 07-18-2012, 11:39 PM   #7
Re: No power.
Make sure you have the firing order correct.
Trojan Horse is offline
Closed Thread
09:54 AM
