Video of my valve train noise - Page 2 - Mustang Evolution
Old 07-20-2012, 12:11 PM   #36
Re: Video of my valve train noise
Originally Posted by JayKranz View Post
I had oil pressure for about ten seconds then it pretty much went away. I checked the plugs in the rear of the block and they were all there. Also, it is a new block not remanufactured.
Even so, the oil system plugs should have been removed and the oiling passages checked and cleaned. So if it was prepped properly they may have inadvertently left out a plug?
Maybe get you an oil pump primer (you can make one from an old distributor) and using a drill try to pressurize the system without the engine running. That should make it easier to see and possibly hear the issue?
How about the oil return holes in the heads and lifter valley?
They weren't accidently plugged up I hope?
Old 07-20-2012, 12:15 PM   #37
The oil return holes looks clear, I've dumped oil down them too and it deains
JayKranz is offline   Reply With Quote
Old 07-20-2012, 12:19 PM   #38
You can also make an oil primer with a long 1/4 drive extension and a socket that fits the oil pump shaft. But I would tac them together so you don't lose the socket in the pan when removing it.
Old 07-20-2012, 01:17 PM   #39
I checked pushrods length again and according to me checker I need 6.2 inch but the stock rods I'm using are 6.25 right? Is that enough to make a difference?
---------- Post added at 02:17 PM ---------- Previous post was at 01:38 PM ----------
Should I spin the pump shaft clockwise out counter? If I spin clockwise nothing happens if I spin counter oil shoots out where the pcv would be.
Old 07-20-2012, 01:29 PM   #40
Yes, it has to spin counterclockwise.
Oil should not shoot out the PCV, There is your problem I believe.
Old 07-20-2012, 01:30 PM   #41
6.2 is close enough.
Old 07-20-2012, 01:31 PM   #42
This is where it shoots from when I spin counter clockwise.
Old 07-20-2012, 01:33 PM   #43
How is it coming out the pcv hole, when he's not even into compression?
Old 07-20-2012, 01:35 PM   #44
I'm using a drill and spinning counter clockwise and oil shoots outta there about two feets above the engine. I also pulled a head and everythin there looks good.
Old 07-20-2012, 01:37 PM   #45
Attachment 59984
That hole should be plugged. There is your problem for sure.
That is the crossover that feeds oil to the other side of your engine.
The valvetrain noise is because that side wasn't getting oiled at all and the other side didn't have any pressure. Crap like that is exactly why I don't trust anyone else to assemble my engines.
Old 07-20-2012, 01:39 PM   #46
Using a drill spinning counter clockwise is the correct way. I am just curious how its coming out there. Usually it is caused by "blow by".
---------- Post added at 02:39 PM ---------- Previous post was at 02:37 PM ----------
Ohhhh ok. That makes perfect sense. at least we know something solid now.
Old 07-20-2012, 01:43 PM   #47
OMG! Haha I can't believe but am happy at the same time that, that is the issue
---------- Post added at 02:43 PM ---------- Previous post was at 02:41 PM ----------
Any idea of a model or size of the plug so I can go get one?
Old 07-20-2012, 01:47 PM   #48
Measure with calipers or ask for the 302/5.0 oil passage crossover plug. (You may have to buy a freeze plug kit?)
It looks like a small freeze plug. Clean off all of the oil and put a small amount of red Loctite on the plug, then drive it in squarely to the stop.
Old 07-20-2012, 01:50 PM   #49
When I build an engine, part of the block prep includes polishing the oil passages and rounding off the sharp edges in that crossover. I also oversize the passage from the oil filter to the oiling passages as much as I can. That coupled with proper oil pump "blueprinting" has easily noticeable effects. My engines always have held really good oil pressure and they have oil pressure almost immediately on start up.
That's my story and I'm sticking to it.
Old 07-20-2012, 01:53 PM   #50
I say its a great story.
I would contact the builder and tell them how much of a dbag they are after I kindly ask for the proper plug.
Old 07-20-2012, 01:55 PM   #51
Lesson learned
Old 07-20-2012, 02:01 PM   #52
+1000 I have a very low tolerance for people who do things like that.
Lesson learned
Sadly, you learned it the same way I did years ago.
I'm just glad you were able to find the issue and it's nothing really serious.
Hopefully there is no damage to bearings or lifters.
Old 07-20-2012, 02:18 PM   #53
I ruined three lifters but I have an extra set so not the end of the world.
Old 07-20-2012, 02:25 PM   #54
Inspect them closely and make sure no metal particles got into the oiling system.
Old 07-20-2012, 02:37 PM   #55
Forum Car Trader
90GTNovi2000's Avatar
Yay!!!!! That's awesome. Jay will have it running by saturday i bet. Congrats!!!!
90GTNovi2000 is offline   Reply With Quote
Old 07-20-2012, 02:50 PM   #56
I definitely will! I would have it running in about four hours if I had a head gasket to put on
Old 07-20-2012, 03:32 PM   #57
Originally Posted by 90GTNovi2000
That doesn't sound horrible hmmm can the lifters collapse? Idk
Sound like the Cummings diesel I have on my boat . Don't drive that lifter or a valve . Probaly a bent valve
tbonestang is offline   Reply With Quote
Old 07-20-2012, 03:55 PM   #58
Forum Car Trader
Lol your a lil late t bone!!
Old 07-20-2012, 06:03 PM   #59
It's good valves with zero oil
Old 07-20-2012, 08:25 PM   #60
All right!
Old 07-21-2012, 09:02 AM   #61
Sorry I don't come on much there Are some members I don't care for very much
Old 07-21-2012, 09:03 AM   #62
Ha yeah understandable
Old 07-21-2012, 09:18 AM   #63
I'm sure that works both ways. Don't let it bother you. I don't.
Old 07-21-2012, 02:22 PM   #64
Exactly.
Old 07-21-2012, 06:48 PM   #65
Here's an On3 kit on a stock engine running 12.3's
Video
Old 07-21-2012, 06:52 PM   #66
Oh that's garbage though. Lol j/k
Old 07-21-2012, 06:55 PM   #67
Nice
Old 07-21-2012, 08:05 PM   #68
Well, it's not good enough for the big city boys or so I've been told.
I guess you can't "drop bank" on the less expensive kits and heaven forbid that you "do it yourself".
Old 07-21-2012, 08:14 PM   #69
Yeah, he was shopping with someone else's money
---------- Post added at 09:14 PM ---------- Previous post was at 09:09 PM ----------
In truth even the piping, clamps and hoses are worth the $1500
Old 07-21-2012, 09:07 PM   #70
Yeah, I'm pretty sure he was clueless and didn't know how to do squat for himself either.
I'd much rather say "I built it" instead of "I had it built by...".
It actually bugs me that my engine shortblock was built by Keith Craft Racing, rather than by myself.
I almost can't wait to tear into it to see how good a job they actually did on it.
01:10 AM
