Video of my valve train noise - Mustang Evolution
Old 07-19-2012, 05:55 PM   #1
In this video you obviously can't see it but oil was being sent to my upper intake and exhaust. I have another thread about this but was unable to figure out which one it was. Sorry.
JayKranz is offline   Reply With Quote
Old 07-19-2012, 06:01 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
That doesn't sound horrible hmmm can the lifters collapse? Idk
90GTNovi2000 is offline   Reply With Quote
Old 07-19-2012, 06:03 PM   #3
I thought it was collapsed lifters. I actually found three questionable ones when I broke it back down. I stool got a half quart of oil in my upper intake though.
Old 07-19-2012, 06:21 PM   #4
Re: Video of my valve train noise
Have you checked to see if the oil is being forced through the PCV valve and tubing into the intake?That sounds like lifters that are not pumping up, but I don't know why unless they are damaged.
Old 07-19-2012, 06:23 PM   #5
There was oil in the pcv tube. The valve was new and not stuck though.
---------- Post added at 07:23 PM ---------- Previous post was at 07:22 PM ----------
Also I was not getting oil pressure so after about five seconds the pre primed oil had probably been pushed out of the lifters though right?
Old 07-19-2012, 06:27 PM   #6
you said before that the screen was in place on the pcv? with that high compression you may need an oil seperator.
Old 07-19-2012, 06:37 PM   #7
Yes, the screen is still there.
---------- Post added at 07:37 PM ---------- Previous post was at 07:28 PM ----------
TH - How would I have no oil pressure but be able to have oil pump through the pcv and in to the intake? Id love to figure this all out
Old 07-19-2012, 06:38 PM   #8
Forum Car Trader
Sending unit could be clogged or something.
Old 07-19-2012, 06:39 PM   #9
I just switched that out too, but with the lifter noise I figured that oil pump may be the issue. I have replaced that as well.
Old 07-19-2012, 06:49 PM   #10
Forum Car Trader
Are your heads plugged off in the rear? I'm sure they are just wondering.
Old 07-19-2012, 06:50 PM   #11
Yes, you mean the smog pump plug right?
Old 07-19-2012, 06:52 PM   #12
Forum Car Trader
Yeah I think. Where the cross over tube would be.. Dam it doesn't sound horrible idk.
Old 07-19-2012, 06:53 PM   #13
It's not horrible, but it's not right either.
---------- Post added at 07:53 PM ---------- Previous post was at 07:53 PM ----------
Biggest issue is all the oil coming out my exhaust and intake.
Old 07-19-2012, 06:56 PM   #14
Forum Car Trader
Damn maybe go grab another set of rebuilt e7's idk bro I'm just tossing ideas out TH will have some better guesses soon I think
Old 07-19-2012, 06:57 PM   #15
Yeah? I was trying to figure out if it's the heads.
Old 07-19-2012, 07:02 PM   #16
you can probably get them checked out at a machine shop for pretty cheap.
Old 07-19-2012, 07:06 PM   #17
Well are they the possible culprit?
Old 07-19-2012, 07:16 PM   #18
i domt see it likely. if an oil passage cracked it would be difficult for the oil to backfeed into the intake from there (i think). also i think when heads crack they are more prone to do it between the valves. im not saying this is impossible but i dont think its the problem.
i wish you could have pulled the pcv when it was doing this, as thats usually how oil gets in there.
Old 07-19-2012, 07:17 PM   #19
Well I think I'm gonna put it back together tomorrow and throw it back in. We will see I guess.
Old 07-19-2012, 07:21 PM   #20
i tried to find any info on cracked heads. nothing much but here http://expertscolumn.com/content/how...-cracked-heads
Old 07-19-2012, 07:23 PM   #21
Yeah I didn't find find much other than an article that said the engine wouldn't run well and normally coolant would be in the oil. I don't have either of those problems.
Old 07-19-2012, 07:23 PM   #22
make sure you set the pickup right. and remember what insaid about using tape on the screen so uou dont clog it with clay?
your old pump was a high volume? if so did you get another high volume? and what pan is on there? if its a high volume you need a 7 quart pan or you will suck it dry.
Old 07-19-2012, 07:25 PM   #23
I took the hv off and put a standard m68 on there. It is not a 7 qt. I used the clay and got it a half inch off the bottom of the pan now. It was very close before.
Old 07-19-2012, 07:30 PM   #24
yeah. you are better off with the standard. if you have problems this time. it would be better if you gave us a little time to come up with some tests. you may have prematurley ripped it apart. i understand the frustation, but we may have been able to get you a better diagnoses after some longer conversation. i feel bad that i cant answer all your questions and that you have went through all this. and it really sucks you are putting it back together without fully knowing what went wrong. but anyways my fingers are crossed that all goes well.
Old 07-19-2012, 07:31 PM   #25
I did a compression test today by hand. Not ideal I know but all cylinders came out around 50 psi from hand cranking and I left each one for one minute and none lost any pressure.
Old 07-19-2012, 07:32 PM   #26
definitly sounds like your rings are good.
Old 07-19-2012, 07:32 PM   #27
I can wait and not put it together yet? I just think Ive replaced everything but the heads.
---------- Post added at 08:32 PM ---------- Previous post was at 08:32 PM ----------
Yeah that's what I thought while I watched the gauge.
Old 07-19-2012, 07:33 PM   #28
i say go for it. just saying it sucks not knowing what the problem was. also saying if there are problem dont rip it apart right away, thats all.
Old 07-19-2012, 07:34 PM   #29
Okay I won't. I just had time and motivation
Old 07-19-2012, 07:37 PM   #30
when this first happened a scenario went through my head after trojan mentioned stuck ring.
i had thought that maybe a ring stuck. then with the oil in the intake going into the combustion chamber. it may have helped free up the rings. but just a scenario i had thought about. that would make senso why you had good compression on the test which wasnafter the original oil problem.
Old 07-19-2012, 07:37 PM   #31
Ah okay. We shall see.
Old 07-19-2012, 07:39 PM   #32
im not sure thats what happened though. just a thought. im betting more something with the oil pump, lifters and a combination of stuff. idk
Old 07-19-2012, 07:47 PM   #33
Well I'm hoping tomorrow afternoon when I get the motor in that it works.
Old 07-20-2012, 11:17 AM   #34
You don't have oil pressure?
Now I'm wondering if they left a plug out of an oil passage somewhere or if the block is cracked.
You will need to install some oil separator(s) in the PCV system and you need to be 100% sure you have adequate crankcase ventilation. Forced induction engines will increase the crankcase pressure considerably and you have to be sure that it is not pushing the oil out.
I'm also still wondering about the turbo oil seals. Is there anyway you can disconnect the turbo from the intake and exhaust and just run it naturally aspirated?
Old 07-20-2012, 12:09 PM   #35
I had oil pressure for about ten seconds then it pretty much went away. I checked the plugs in the rear of the block and they were all there. Also, it is a new block not remanufactured.
---------- Post added at 01:09 PM ---------- Previous post was at 12:48 PM ----------
Also, oil is coming from both sides of the engine. The turbo doesn't push backwards so I was thinking because I that the oil was not coming from the turbo. Oil was in the cylinders as well. That's all the detail I have
02:04 AM
