Sub-Frame Connector? - Mustang Evolution
Old 07-21-2012, 01:08 PM   #1
kickerofdoom's Avatar
What kind of subframe connector do people recommend for a fox body mustang. I wanna get one just to be safe
Old 07-21-2012, 01:34 PM   #2
Re: Sub-Frame Connector?
Any good name brand with the seat supports and weld ins are stronger than bolt ins.
I have the Kenny Brown Super Subs on my car and they are good quality pieces, but Maximum Motorsports and other name brand subs are probably just as good.
Old 07-21-2012, 01:39 PM   #3
Well i have mm subframe on my other car i just wanted to see what people think and have. I know this is like the first mod you should add
Old 07-21-2012, 01:44 PM   #4
Yes it is.
If I were buying today I would probably go with the full length MM subs.
Old 07-21-2012, 03:41 PM   #5
Ok now that out of the way is Cai worth the money. The 87 has no Maf but i don't wanna change it yet. What kind of kit can i get and what kind of gears should I get
Old 07-21-2012, 03:51 PM   #6
Not until you change over to MAF. It's not worth wasting the money and changes to the air flow on a speed density engine can be detrimental to its operation.
3.73 for manual trans and 4.10 for auto are the usually recommended ratios.
Old 07-21-2012, 04:02 PM   #7
It's a stock aod would a shift kit be worth it to install?
Old 07-21-2012, 05:24 PM   #8
I don't think so without beefing up the clutches and other components.
The AOD is pretty weak, so before adding much in the way of performance you might want to get it rebuilt with some upgrades to handle the extra power without it puking on you.
Maybe this place can help guide you through what is needed.
Ford AOD
Old 07-21-2012, 05:36 PM   #9
I think i found what parts I want to get. Subframe connector and some underpulleys which one are best or they all the same?
Old 07-21-2012, 05:39 PM   #10
I wouldn't use UD pulleys. IMO they cause more problems than they do good.
Old 07-21-2012, 05:49 PM   #11
O ok
Old 07-21-2012, 06:07 PM   #12
O ok
Go ahead and install the subframe connectors, replace the upper and lower rear control arms with aftermarket ones, remove the quad shocks, and upgrade the brakes.
Then save up and do the MAF conversion .
After that add your engine performance parts as you can afford to.
Old 07-21-2012, 06:31 PM   #13
Yeah and maybe some gears
Old 07-24-2012, 02:20 AM   #14
I have the mm full length subframe connectors with the upper and lower torque boxes as well.
1980 Mercury Capri
347 Dart block with forged rotating assembly
Procharger D1SC Tremec TKO600
GT40 intake with 42# injectors
4.10 rear
StrokedNBlown is offline   Reply With Quote
11:45 PM
