confused - Mustang Evolution
Old 07-22-2012, 09:05 AM   #1
captain78's Avatar
confused
Ok i built my motor up rpm surging bad like between 1000-2000. I changed every sensor O2s .tps iac still won't idle i was told there was a super chip in it. So pulled ecu and there was a hypertech chip i was told to pull it So i just did. Still same thing how can you tell if computer bad. Or what else could it be
captain78 is offline   Reply With Quote
Old 07-22-2012, 09:19 AM   #2
Lorraine's driver
ab_mach1's Avatar
Did you check your MAF sensor? Make sure it's plugged in and that the wires are not damaged.
Instagram: @ab_mach1
Old 07-22-2012, 09:24 AM   #3
captain78's Avatar
Yep everything brand new plugged in and wires are all good.
Old 07-22-2012, 09:28 AM   #4
Re: confused
Check your "Ten Pin" connectors and make sure they have good contact by following the procedure below. Then do a "Base Idle Reset" per your Chiltons manual and see what happens.
1. Take the 10 pin connectors apart (salt and pepper shakers, behind the TB).
2. Carefully use a fine pointed pick tool to spread the male terminals open more so they make better contact. In the center of each male terminal there is a small hole and seams down the sides of the terminal which will allow you to spread them open a bit.
3. Apply some dielectric grease to the terminals
4. Plug the connectors back together.
Old 07-22-2012, 09:32 AM   #5
Lorraine's driver
ab_mach1's Avatar
Trojan, what year did they start using MAF's, 1988?
Old 07-22-2012, 09:33 AM   #6
Re: confused
Yes, on the California cars.
Old 07-22-2012, 09:38 AM   #7
captain78's Avatar
How big a cam before car just needs a tune cause I've heard the cars computer can adjust itself to what I've got i just dunno if i should just bring it to a specialist for a good tune
Old 07-22-2012, 09:41 AM   #8
Re: confused
Mine is running the X303 without any issues.
I don't think you need to worry about it until you go really big, and use high compression or forced induction.
Old 07-22-2012, 10:30 AM   #9
93slowstang's Avatar
Do you have the jumper for your ten pin connectors? If I remember correctly the 90 models needed it to idle properly.
Old 07-22-2012, 10:38 AM   #10
captain78's Avatar
Yes i have them
Old 07-22-2012, 10:38 AM   #11
Re: confused
+1
I completely forgot about that issue.
Here's some info and pics - Ten Pin Connector Fix
Old 07-22-2012, 12:30 PM   #12
captain78's Avatar
Thanks ill check it out
Old 07-24-2012, 06:08 AM   #13
captain78's Avatar
Ok found out what's wrong it my air fuel mix is very wrong. Regulated fuel and it idled down.
Old 07-24-2012, 06:32 AM   #14
Forum Car Trader
90GTNovi2000's Avatar
Awesome so is it running good now?
90GTNovi2000 is offline   Reply With Quote
Old 07-24-2012, 06:36 AM   #15
captain78's Avatar
Still have bugs to work out now that i know what the problem is or was now just gotta reset timing and tps and adjust my iac. And with the miles i put on her since the build. Pull the valve covers readjust valves if needed and should be good
05:26 AM
