Got it running! 331 Stroker Turbo - Page 2 - Mustang Evolution
Old 07-24-2012, 08:05 PM   #36
okay, I'll remove and clean them tomorrow.
JayKranz is offline   Reply With Quote
Old 07-25-2012, 02:50 PM   #37
Cleaned oxygen sensors. Still idles for awhile then dies. Getting too much has and fouling plugs still
---------- Post added at 03:50 PM ---------- Previous post was at 03:50 PM ----------
too much gas not has(auto correct)
Old 07-25-2012, 02:53 PM   #38
Re: Got it running! 331 Stroker Turbo
You checked the fuel pressure right? Is it all cylinders or just one or two?
I wonder about your tune, it was done with a chip correct?
Old 07-25-2012, 02:53 PM   #39
its definitly fouling all the plugs? just wondering if maybe you had a cylinder not firing or wrong firing order. or just goofed a couple plug wires.
also check the tps
Old 07-25-2012, 02:55 PM   #40
plug wires are good, all cylinders are being fouled and it does after a minute or two. My tune is custom on an sct chip. my tuner said with no boost it should run as goo now as it did before.
Old 07-25-2012, 03:01 PM   #41
is it possible the higher compression is vacuuming in more fuel?
Old 07-25-2012, 03:02 PM   #42
How's your pressure regulator? A backfire or hiccup could possibly blow out the diaphragm.
Old 07-25-2012, 03:38 PM   #43
Its a new stock regulator. I installed it right before I had problems with my other motor.
---------- Post added at 04:38 PM ---------- Previous post was at 04:04 PM ----------
I'm about three tests away from throwing a carve irate on this sucker!
Old 07-25-2012, 03:47 PM   #44
dont let it get you bent out of shape. i know thats hard with what you have dealt with.
whats the fuel pressure?
if you cant figure it out maybe just let the tuner take care of it?
Old 07-25-2012, 03:48 PM   #45
I meant a carb on this.
Old 07-25-2012, 03:57 PM   #46
lol. i was wondering.
Old 07-25-2012, 04:30 PM   #47
tps measured at .61 with it fully adjusted it can't spin any more. Sound like a bad tps?
Old 07-25-2012, 04:35 PM   #48
yes. it shouldnt be that low. it should be more around .98-.99
you might be able to slot the holes? ive read of guys doing that. if not you may need a new one.
Old 07-25-2012, 04:36 PM   #49
it's $35 so I'll get one and see.
Old 07-25-2012, 04:42 PM   #50
cool. let us know.
Old 07-25-2012, 06:56 PM   #51
New tps, now it idles at 2800 rpm
Old 07-25-2012, 06:57 PM   #52
you still probably need to set it.
Old 07-25-2012, 06:58 PM   #53
Set to what, I set it to .98 and that's what I get also the screw is pretty much all the way in at .98
Old 07-25-2012, 07:03 PM   #54
http://www.muscularmustangs.com/tps.php
if its @.98 then it should be good. but thats not really @ idle. try resetting the idle and then check voltage again. sounds like you just need to reset it. use the proper procedure to set idle to.
Old 07-26-2012, 05:49 AM   #55
Thanks, how do I set the idle screw when the cars running funky? The computer seems to adjust everytime I turn it.
Old 07-26-2012, 07:13 AM   #56
Did you use the procedure like in the useful thread?
http://mustang.blogsome.com/2005/10/...le-adjustment/
Or just try adjusting it?
Old 07-26-2012, 07:19 AM   #57
Lorraine's driver
ab_mach1's Avatar
Congrats Jay!
Instagram: @ab_mach1
Old 07-26-2012, 04:10 PM   #58
37-38lbs fuel pressure
tps .98
cleaned carbon from iac
idle set to 700-800rpm
Rums great when the tps is NOT plugged in
This is a video of it running without the tps connected. I also removed my custom tuned chip
Old 07-26-2012, 04:21 PM   #59
Forum Car Trader
90GTNovi2000's Avatar
That is awesome.. I see your still burning off oil but it's all good... So how long until you take it for a tune?
90GTNovi2000 is offline   Reply With Quote
Old 07-26-2012, 04:35 PM   #60
its getting over my head hear jay. but what you did unplugging the tps is send the ecu in a open loop or limp mode. basically a fixxed set of parameters that the ecu goes into when itmcant get all the info it needs. it will work like this but not recommended for a long period of time. so still some issues. what i dont understand is unplugging it usually fixxes tps issues. and you have replaced tps. .
Old 07-26-2012, 04:48 PM   #61
Yes, replaced and recalibrated tps. When I plug it in and start the car it will idle up and down and eventually stall.
Old 07-26-2012, 04:54 PM   #62
Lorraine's driver
ab_mach1's Avatar
tps .98
I she smokey because of the oil blow-by from the first try?
Old 07-26-2012, 04:55 PM   #63
Probably "I hope"
Old 07-26-2012, 04:57 PM   #64
Lorraine's driver
ab_mach1's Avatar
I don't remember foxes having this when I had one, but does the ECU need to learn idle like the 99+ Mustangs?
Old 07-26-2012, 04:59 PM   #65
Yes they do.
Old 07-26-2012, 05:04 PM   #66
Lorraine's driver
ab_mach1's Avatar
Cool, If it's a Ford thing, maybe this procedure will work...
Old 07-26-2012, 05:32 PM   #67
Lapida's Avatar
- Disconnect Battery Ground cable
- Turn on ignition key, head light switch and press brake pedal for 30 seconds
- Turn off ignition key, head light switch and release brake pedal. Does not matter which order you do these steps.
- Re-connect Battery Ground cable
Make absolutely sure the timing is set at the stock value of 10 deg initial. Verify that the fuel pressure is set to the stock value of 39psi. This is checked with the vacuum removed from the regulator, but both must be plugged/blocked off while checking the setting.
Build a payload as specified below and log from a cold start to operating temp (approximately 160degF) at idle. After the vehicle reaches operating temp, use the throttle to raise the RPM to the below approximate levels for 60 seconds each.
1000 RPM @ 60secs
1500 RPM @ 60secs
2000 RPM @ 60secs
2500 RPM @ 60secs
Release the throttle and let the RPM's drop on their own and stabilize. If the vehicle wants to stall, let it idle on its own until it stalls and then restart. Spend the next 10 to 20 minutes driving in normal traffic. This will build the fuel trims or wideband data in the rpm range for closed loop operation.
Lapida is offline   Reply With Quote
Old 07-26-2012, 05:37 PM   #68
Okay, is this with or without the TPS connected?
Old 07-26-2012, 05:39 PM   #69
With.
Old 07-26-2012, 05:39 PM   #70
okay, thanks everyone
02:21 PM
