Got it running! 331 Stroker Turbo - Page 3 - Mustang Evolution
Old 07-26-2012, 05:39 PM   #71
Lapida's Avatar
Originally Posted by JayKranz
Okay, is this with or without the TPS connected?
Connected.
Lapida is offline   Reply With Quote
Old 07-26-2012, 06:19 PM   #72
Re: Got it running! 331 Stroker Turbo
With a new engine it will take some time for the ECU to learn and input the correct parameters. Also keep an eye on those O2 sensors and make sure they don't get contaminated by the excess oil again.
Old 07-26-2012, 06:20 PM   #73
Okay, I'll try again tomorrow.
JayKranz is offline   Reply With Quote
Old 07-26-2012, 06:31 PM   #74
Lapida's Avatar
If the tuner disable the driver side o2 sensor only buy a new one with the extension harness.
Old 07-26-2012, 06:34 PM   #75
He actually replace them with new ones and said I need to use them.
Old 07-26-2012, 06:38 PM   #76
Lapida's Avatar
The sensors are located on the passenger side after the wideband one next to the other?
Old 07-26-2012, 06:41 PM   #77
I dont have wideband as far as I know. I have an oxygen sensor on the passenger side header and one on the driver side header. Isn't that normal?
Old 07-26-2012, 06:42 PM   #78
foxes dont have wideband unless instlled aftermarket.
Old 07-26-2012, 06:48 PM   #79
Lapida's Avatar
I think is ok.
In my setup I have the wideband like 6 inches after the turbo and one O2 sensor on the downpipe.
Good luck!
Old 07-26-2012, 06:58 PM   #80
Ah okay, that makes sense
Old 07-26-2012, 06:59 PM   #81
Yes, that is normal.
Old 07-26-2012, 06:59 PM   #82
Lorraine's driver
ab_mach1's Avatar
Thanks for the proper re-learn procedure Lapida!
Instagram: @ab_mach1
Old 07-27-2012, 03:16 PM   #83
I can't get it to idle below 1600rpm and this is coming from my exhaust.
Seems to be gas and oil?
Old 07-27-2012, 03:21 PM   #84
It idles great at about 800rpm until I plug the IAC in. Then it does the higher idle.
Old 07-27-2012, 03:27 PM   #85
Is that old oil? Is it getting worse, staying the same, or getting less ?
Old 07-27-2012, 03:28 PM   #86
I would say about the same.
Old 07-27-2012, 03:30 PM   #87
I would try taking the iac off and spray it with some carb cleaner.
---------- Post added at 04:30 PM ---------- Previous post was at 04:29 PM ----------
That's not good. That means your still losing oil somewhere. I'm sure you had lots in your exhaust. But I was hoping it would go away.
Old 07-27-2012, 03:32 PM   #88
I already cleaned it very well with qtips.
---------- Post added at 04:32 PM ---------- Previous post was at 04:31 PM ----------
I'm thinking valves?
Old 07-27-2012, 03:37 PM   #89
i fell like we just went backwards. damn it!
your probably oiling down your o2 sensors. which could be part of your idle issues.
what are these heads off of? i think the valves would be ok due to your previous compression test?
is there any oil in the pcv and intake again?
Old 07-27-2012, 03:40 PM   #90
O2 are clean, no oil in pcv or intake. It's definitely coming from the cylinders. I don't know cu my compression is very good. Also I'm not losing any oil level and pressure is good.
---------- Post added at 04:40 PM ---------- Previous post was at 04:39 PM ----------
they are from a 5.0 that was running and the guy bought a trick flow top end kit.
Old 07-27-2012, 03:40 PM   #91
well how long did it run then? are sure it isnt left over oil in the exhaust? i dont see how your o2 can be clean with that running through
Old 07-27-2012, 03:41 PM   #92
It will run as long as I leave it on. I ran for about fifteen minutes though and shut it off.
Old 07-27-2012, 03:42 PM   #93
damn. and still spit oil after that then somethings probably wrong if it didnt improve.
Old 07-27-2012, 03:43 PM   #94
Yeah, I just can't figure out what.
Old 07-27-2012, 03:44 PM   #95
maybe we need trojans input?
basically good compression all cylinders.
but spitting oil out of exhaust
Old 07-27-2012, 03:45 PM   #96
Exactly and idles fine until I plug in the IAC.
Old 07-27-2012, 03:47 PM   #97
maybe the iac needs replaced. imo oil in the exhaust could be throwing o2 readings off. even if they look clean.
have you pulled a plug to check for oil?
Old 07-27-2012, 03:47 PM   #98
Yes, they are fouled out and black.
Old 07-27-2012, 03:49 PM   #99
thats also some of your idle issue.
im not sure how to do the more complicated tests in tracking down your oil leak.
Old 07-27-2012, 03:50 PM   #100
I the oil is coming from the cylinders or the vales but I think that's the only place it could really.
Old 07-27-2012, 03:54 PM   #101
whats still fishy is that its all cylinders again. if it were something like cracked block or head gasket you probably wouldnt see oil in every cylinder.
were as last time it made sense being that it was getting sucked in through the intake.
Old 07-27-2012, 03:57 PM   #102
Exactly
Old 07-27-2012, 04:16 PM   #103
Forum Car Trader
90GTNovi2000's Avatar
You might be able to pull your driver side header and take a peek.. Wow that's crazy. It just looks like fuel that has passed through the exhaust and picked up carbon along the way. It's like you have a carb and your washing the cylinders down with fuel.. How does it smell during idle? Does it choke you? Or is it decent?
90GTNovi2000 is offline   Reply With Quote
Old 07-27-2012, 04:17 PM   #104
It's okay, but definitely getting too much has still. Not sure of this is something I should let the tuner handle or what? Is this as far as I can take it on my own?
Old 07-27-2012, 04:21 PM   #105
Forum Car Trader
I wouldn't take it to the tuner just yet.. Let TH toss in his 2 cents and see what the hell is going on... Pull your dip stick.. Do you smell fuel?
---------- Post added at 05:21 PM ---------- Previous post was at 05:20 PM ----------
Does the engine oil smell like fuel is what I mean.
12:13 PM
