Got it running! 331 Stroker Turbo - Mustang Evolution
Old 07-22-2012, 08:15 PM   #1
It ran! I have oil pressure. I set the timing. I put the spout connected back in and now I can't get it to start again
JayKranz is offline   Reply With Quote
Old 07-22-2012, 08:33 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
HELL YEAH!!!!!!!!!!!!!!!!! now tomorrow time for engine break in then oil change again!!! That's sweet just some lil bugs to work out. When are you getting it tuned?
90GTNovi2000 is offline   Reply With Quote
Old 07-22-2012, 08:35 PM   #3
Hopefully next weekend.
---------- Post added at 09:35 PM ---------- Previous post was at 09:34 PM ----------
What should I do for break in?
Old 07-22-2012, 08:37 PM   #4
Still sounds like timing to me. Did you shut the car to put the spout back in?
Also could he a vacuum leak.
And congratulations! No for the debugging phase.
Old 07-22-2012, 08:39 PM   #5
Forum Car Trader
A new debate... Warm it up to operating temp and lightly drive or leave it running for about a hr. change oil with a strainer check for signs of engine shavings etc.... Fill it back up and run it for a while keep an eye on your oil I'd say give it 400 or so miles and it should be ready for WOT.. But I wanna see what TH says
Old 07-22-2012, 08:42 PM   #6
Could be vacuum. I think you are right with timing though. I set it to 10btdc and it ran but not great. I'm gonna set it back to 0 and then ten and leave it til my tuner calls me back. Could he have put something in my SCT chip that would make it not start if I set to ten and then put the spout connector back in?
Old 07-22-2012, 08:47 PM   #7
I agree with that. But I may even wait until the tuner gets her to.
Old 07-22-2012, 08:48 PM   #8
Yeah, I probably shouldn't mess with it now that I know that it can run.
Old 07-22-2012, 08:49 PM   #9
The chip may very well control certain timing events. I'm not exactly sure how they work or what's been programmed. At this point you may as well let the tuner handle it.
Old 07-22-2012, 09:01 PM   #10
okay
Old 07-22-2012, 10:04 PM   #11
re: Got it running! 331 Stroker Turbo
First have it tuned before you drive it much at all and make sure it does not detonate. I don't think the chip has anything to do with it not starting after you put the spout back in, but I guess it could be possible.
Take it easy for about the first 300-500 miles, running it up and down through the RPM range and go through several heating and cooling cycles without going to WOT for the first 100-200 miles. Then after 500 miles change the oil/filter and drive it like you intend to. The oils and metals used today are much better than what used to be available, so the break in shouldn't take long. You could even take some hot compression readings before and after to check on how well the rings are seating in if you wanted to.
P.S. Make sure you have good crankcase ventilation. You don't want it to over pressurize and blow out the seals and gaskets.
Old 07-22-2012, 10:06 PM   #12
Cool thanks! First I gotta get it to start again
Old 07-22-2012, 10:08 PM   #13
It still sounded like the lifters/rockers were rattling quite a bit.Since that plug was left out of the back of the block are you sure the ones in the front oil galleys were installed?
Old 07-22-2012, 10:10 PM   #14
I "think" so. My oil pressure was good too.
---------- Post added at 11:10 PM ---------- Previous post was at 11:09 PM ----------
I kept checking oil levels also and I didn't have any disappear.
Old 07-22-2012, 10:17 PM   #15
Ok, just keep an eye on the pressure and maybe they just need a bit longer to warm up and wear in.
Old 07-22-2012, 10:18 PM   #16
It only ran for about ten seconds longer than the video.
---------- Post added at 11:18 PM ---------- Previous post was at 11:17 PM ----------
I hope so. I'm gonna light in on fire if it doesn't work this time
Old 07-23-2012, 05:36 PM   #17
Got it running again today, a little longer this time. I have oil pressure, engine temp, no leaks, almost no smoke left. She sounds mean! I have the timing at ten btdc, but it doesn't idle very high. 500-600 rpm and them after a couple minutes dies.
No valve train noise btw!!!!!
Old 07-23-2012, 05:57 PM   #18
Sweet man. I think its definitely tuner guy time. Just don't get impatient on us. You have to be very very careful with compression ratio.
Old 07-23-2012, 06:01 PM   #19
I took the waste gate spring out = 0 boost Not taking any chances. I spoke with Mike(Tuner) today. I need to add meth injection with my compression then I can safely run 5lbs of boost until I get aluminum heads with a bigger cc.
I do need to get it to run more than a few minutes though.
Old 07-23-2012, 06:31 PM   #20
Very true. Get it running a little better first. It will be a little safer with 0. Lost. But you still need to be a little cautious with that high compression.
Old 07-23-2012, 07:18 PM   #21
Forum Car Trader
Dam I would buy some decent heads off the net.. How much is a meth injection setup?
Old 07-23-2012, 07:20 PM   #22
Heads are a winter project. The meth kit is $325 from snow performance.
Old 07-23-2012, 07:33 PM   #23
I say wait on slowstang for his head Jo. He is gonna do. He is gonna use flotek heads. They are very well priced. If they do good for him, it maybe easir on the wallet.
Old 07-23-2012, 07:39 PM   #24
Fantastic! You may have to do a base idle reset since you have a few more cubes now.
That's a definite. One little bit of detonation can be very bad.
The Snow kit is a great kit, but it's expensive.
I'm going to use the AFM Mr. Freeze kit which is around $189.
I have heard that some don't like it and claim that it uses too much methanol mix, but I believe that is because they don't have it jetted properly.
The "jets" are nothing more than MIG welder tips, so you could fab your own in custom sizes if you need to fine tune your mix.
Old 07-23-2012, 08:13 PM   #25
Base Idle Reset?
---------- Post added at 09:13 PM ---------- Previous post was at 09:10 PM ----------
Does this look like good instructions?
http://www.moddedmustangs.com/forums...dle-reset.html
Old 07-23-2012, 08:35 PM   #26
Base Idle Reset?
5.0 Base Idle Reset
Yes, Joel 5.0 is very knowledgeable and I would trust his instructions even if they vary from the manufacturers.
Old 07-23-2012, 08:40 PM   #27
cool
Old 07-23-2012, 08:56 PM   #28
Re: Got it running! 331 Stroker Turbo
cool
Joel is one of the best 5.0 Fox Body techs you will find on the net.
I have learned quite a bit from him over the years.
Anytime you have something you want to look up or check and I can't help you for whatever reason, look for posts about your issue in his name. You can be assured his recommendations and answers will be correct.
Old 07-23-2012, 08:57 PM   #29
Definitely! Thanks
Old 07-24-2012, 04:47 PM   #30
Got here car started right up. Let it idle for a few. It was rough. Shut it off, now it won't restart. It the weirdest thing.
Old 07-24-2012, 05:20 PM   #31
Are you sure your fuel pressure, timing and distributor wiring are correct? Is the MAF ok? Wondering if it spit any oil out to it maybe?
Did you change cams or not? If so maybe the cam you used has the older firing order?
Just thinking, grasping at straws so to speak.
Old 07-24-2012, 06:00 PM   #32
Yeah, distributor is good. My mag looks clean and it's in a spot difficult for oil to get too since it welded in to the cold side of the piping. Timing is good I had checked it again while it was running.
---------- Post added at 06:25 PM ---------- Previous post was at 06:24 PM ----------
Cam is aftermarket Lunati that comes with the modern Holley top end kit. I would think it'd be okay plus it's been running.
---------- Post added at 06:25 PM ---------- Previous post was at 06:25 PM ----------
I can smell gas so?
---------- Post added at 07:00 PM ---------- Previous post was at 06:25 PM ----------
I am definitely getting too much fuel. Can't figure out why though.
Old 07-24-2012, 06:18 PM   #33
Is it idling high?
If any sensors aren't right they may take the ecu into an open loop. Which is usually rich at idle. Also could be a vacuum leak.
Old 07-24-2012, 06:28 PM   #34
low idle
---------- Post added at 07:26 PM ---------- Previous post was at 07:25 PM ----------
There's only four or five vacuum lines and I can't find a leak. So frustrating.
---------- Post added at 07:28 PM ---------- Previous post was at 07:26 PM ----------
If my oxygen sensors were covered in oil could that cause this?
Old 07-24-2012, 08:00 PM   #35
low idle
Yeah, that would do it.
02:45 AM
