Can my blowthrough PMAS be calibrated from 42 to 60 lb injectors? - Mustang Evolution
Old 07-24-2012, 08:53 PM   #1
---------- Post added at 09:53 PM ---------- Previous post was at 09:53 PM ----------
Trying to figure out if I just need injectors or a new mad as well.
JayKranz is offline   Reply With Quote
Old 07-24-2012, 11:40 PM   #2
Re: Can my blowthrough PMAS be calibrated from 42 to 60 lb injectors?
If you change injectors the MAF has to be matched to them.
If they are still in business, they should be able to reprogram it.
Or, you can go with an ABACO MAF and never have to worry about changing injector size and reprogramming again. You can do it yourself on a laptop or desktop PC. They also hold several different tunes and you can fine tune if you need to.
The larger injectors (42lb & Up) are known to cause hard starting & idling problems and it takes some special tuning to work around it. You may want to save up for the AFM PMS instead of spending all your money at a tuners. Then you can tune your car as you need to, when you need to and it has provisions for tuning out the large injectors starting and idling issues.
Videos on using the PMS:
Vid 1
Vid 3
Old 07-25-2012, 06:34 AM   #3
Forum Car Trader
90GTNovi2000's Avatar
Awesome videos i just got through the first one I never thought it was that simple
90GTNovi2000 is offline   Reply With Quote
Old 07-25-2012, 02:48 PM   #4
Yeah, it's not bad at all.
Somewhat akin to learning a new game or program on your PC.
05:37 PM
