Timing question - Mustang Evolution
Old 07-25-2012, 10:38 AM   #1
Timing question
Im making this harder then it is but please chime in. I have a 306 with what I was told has a B303 cam. I checked the timing with the spout connector out it was retarded 10but with the connector in its advanced 10. I'm suppose to read what the arrow is at right? With or without connector in? Thanks in advance
GT89 is offline   Reply With Quote
Old 07-25-2012, 10:49 AM   #2
Spout connector out to set timing
Old 07-25-2012, 10:58 AM   #3
Ok thanks, suggestion what timing should be?
Old 07-25-2012, 11:06 AM   #4
93slowstang's Avatar
Factory is 10* advance with spout connector out. You can advance it to around 14-16* but it may require using higher octane fuel to prevent detonation.
Old 07-25-2012, 11:20 AM   #5
I already run 93 but every other half tank gets 100. I have e7 heads with larger valves in it does that change any which timing should be? Thanks again
---------- Post added at 12:20 PM ---------- Previous post was at 12:17 PM ----------
Also meant to ask is that normal for a car to run 10 degrees retarded? Doesn't seem to be lagging idles smooth and peppy....
10:56 AM
