bogging like crazy - Mustang Evolution
Old 07-25-2012, 06:58 PM   #1
5.0ya's Avatar
bogging like crazy
So after I changed my cap and rotor to msd I started having starting issues and problems keeping the car running.. put the stock back on and now it's bogging so bad I can't even drive it..any ideas?
5.0ya is offline   Reply With Quote
Old 07-25-2012, 06:59 PM   #2
did you mix up the wires?
Old 07-25-2012, 07:24 PM   #3
5.0ya's Avatar
No I just went out and checked looking at the diagram on a thread from here.. all appear to be in order
Old 07-25-2012, 07:28 PM   #4
Forum Car Trader
90GTNovi2000's Avatar
Damn you dream!!!!!! I need a new avatar now...
---------- Post added at 07:28 PM ---------- Previous post was at 07:28 PM ----------
Which firing order did you use?
90GTNovi2000 is offline   Reply With Quote
Old 07-25-2012, 07:30 PM   #5
that would be the only thing i can think of you could have messed up would be the firing order
you sure the diagram/firing order you looked at was for the proper engine? HO or non HO?
---------- Post added at 07:30 PM ---------- Previous post was at 07:30 PM ----------
lol
Old 07-25-2012, 07:40 PM   #6
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
lol
+1 it will run on the non h/o firing order but runs like crap
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 07-25-2012, 07:58 PM   #7
5.0ya's Avatar
Hmm do I want to follow the 13726548 or 15426378
the body is a 94 but my engines an 86.
ID:	60869   Click image for larger version
Old 07-25-2012, 08:06 PM   #8
86 is a roller motor right? sorry i forget. but i think it is, so you probably need the ho
Old 07-25-2012, 08:13 PM   #9
Pete Jones
Yup, if I'm remembering correctly the 86 was first year for EFI rollers in mustangs.
90 LX hatchback
89 LX Notchback
Old 07-25-2012, 08:15 PM   #10
did you use the 13726548?
Old 07-25-2012, 08:18 PM   #11
5.0ya's Avatar
Yah I'm pretty sure it's a roller.. I bought it thinking it had a 94 engine so I'm not to educated on this block.. so the Ho is the order beginning with 1,3,7?
---------- Post added at 07:18 PM ---------- Previous post was at 07:18 PM ----------
Yes sir I did.
Old 07-25-2012, 08:19 PM   #12
it should be right then. as long as you didnt goof one. hmmmm....
Old 07-25-2012, 08:22 PM   #13
Pete Jones
Hmmmm, I would say try the other firing order but I don't know if it will matter. You can essentially make any of them number 1 on the distributor but thereis a possibility that it might be 180 out if it will start and run but run like crap.
Did you change out the dist for an msd or just the cap and rotor button?
90 LX hatchback
89 LX Notchback
Old 07-25-2012, 08:28 PM   #14
5.0ya's Avatar
Just the cap and rotor, haven't touched the dist at all. Also sounds like there's a whinning noice coming from that area. I'm thinking it might just need a new cap and than go from there?
Old 07-25-2012, 08:39 PM   #15
Pete Jones
It's a possibility, if your wires are going to the correct places. If anything maybe try just the MSD cap with the old rotor and vice versa and see what it does there.
90 LX hatchback
89 LX Notchback
Old 07-25-2012, 10:31 PM   #16
thomas91gt's Avatar
Same thing that's happened to mine... Im Still having problems with it lol
thomas91gt is offline   Reply With Quote
Old 07-26-2012, 05:30 AM   #17
5.0ya's Avatar
Just dawned on me...at the time I changed it I didn't know the engine is an 86 and bought the cap n rot for a 94. If the rotor on the is still for a 94 would that be an issue?
Old 07-26-2012, 06:37 AM   #18
Pete Jones
It could be, take it back and get one for an 86 and give it a shot.
90 LX hatchback
89 LX Notchback
Old 07-26-2012, 04:06 PM   #19
5.0ya's Avatar
Will try that, checking the timing and fuel pressure all on sat. Thanks for the help and will post after I finish.
Old 07-28-2012, 12:18 PM   #20
5.0ya's Avatar
Hey, could it be a bad TPS?
Old 07-28-2012, 12:33 PM   #21
Pete Jones
Possibly, before you go buy a new one thereis a procedure in the useful info section that can show you how to test it.
90 LX hatchback
89 LX Notchback
Old 07-29-2012, 11:06 AM   #22
5.0ya's Avatar
So, cap b rot, firing order, plugs and wires all good. Took off the tps and ran good but than died.. put it back on ran boggy again.. I'm lost.
Old 07-29-2012, 08:04 PM   #23
Jeff44's Avatar
You have to back track because I assume before you changed it out were you having this problem? If that is the case, maybe one of your wires are defective.
Jeff44 is offline   Reply With Quote
Old 08-02-2012, 08:35 AM   #24
5.0ya's Avatar
Yah I have and I'm going to start with working on fuel being the culprit. First fuel filter change.. any advice in completing the replacement?
Old 08-03-2012, 04:05 AM   #25
Jeff44's Avatar
Just release the pressure before you change it out. Other than that it is pretty simple to do.
Old 08-03-2012, 10:53 AM   #26
Re: bogging like crazy
If you don't have one get a Chiltons manual for your car. They have all sorts of specs and troubleshooting procedures in them. Make sure you get one with the wiring diagrams as they can be very useful in the event of electrical problems.
Old 08-03-2012, 06:39 PM   #27
5.0ya's Avatar
Just bought one, thanks man.
Old 08-03-2012, 09:27 PM   #28
Good deal.
Now you'll have all sorts of useful info right at your fingertips.
If you get confused about anything in it, just let us know and we'll help you sort it out.
Old 08-05-2012, 12:37 AM   #29
Krazy Horse's Avatar
Try cleaning the throttle body then use cleaning foam on the mass air sensor,should fix u up if ur cap n rotor r on right. The rotor button n cap should all b same from 86 - 95 on H.O 5.0. Worst case will idle air valve sticking, have 4 fox 5.0 so really have practice with them
Krazy Horse is offline   Reply With Quote
Old 08-05-2012, 09:06 AM   #30
5.0ya's Avatar
Sounds good, I did clean the MAF thoroughly with maf cleaner and a cotton swab as well just replaced the button. Will the foam remove more than the standard maf cleaner?
Old 08-05-2012, 12:55 PM   #31
Yes it will, can use on idle air also should quit bogging as long as u have better than 46 psi fuel pressure
Old 08-05-2012, 05:22 PM   #32
5.0ya's Avatar
Awesome will do. I'm going to test the voltage on my maf and iac but im new to this part of trouble shooting and am confused on meter setting and how to check it..any advice?
Old 08-05-2012, 05:25 PM   #33
deadsp0t's Avatar
Mine had a bogging issue over 3k at WOT.. Problem was a combo of plugs, wires, cap n button and timing. Still has a slight miss, coil is next. It's like a whole new car now though.
That's unimpressive
Old 08-05-2012, 06:33 PM   #34
5.0ya's Avatar
True, I changed every thing listed above aside from the dizzy.
Old 08-05-2012, 06:35 PM   #35
Have u tested the hall sensor?
01:08 AM
