Problems again? - Mustang Evolution
Old 07-25-2012, 06:34 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Problems again?
Okay I know my motor has problems.. But it seams to got from running good/great.. To running like COMPLETE sht in like a flip of a switch.. The car sound diffrent all together it runs ruffer sounds worse ect but I can drive it do like 10 min and it's okay and then just instantly just horrible.. Any ideas ware to start
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-25-2012, 06:37 PM   #2
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
What's your fuel pressure running at when it does this? Does it pop and crack while giving it throttle? What happens of you ease the throttle to wide open?
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 07-25-2012, 06:45 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
My fuel pressure is okay.. And no it runs better when I give it throttle.. It pops and crack when inlet off..
2001 GT - True Blue
Old 07-25-2012, 06:52 PM   #4
Pete Jones
Are you using a fuel pressure gauge or just checking the valve? Not trying to make you sound dumb just trying to help
90 LX hatchback
89 LX Notchback
Old 07-25-2012, 06:55 PM   #5
sounds like a possible ignition or timing issue. maybe unburnt fuel igniting when releasing throttle?
Old 07-25-2012, 06:59 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
I have an inline fuel pressure gauge..
---------- Post added at 07:59 PM ---------- Previous post was at 07:58 PM ----------
It seams to be getting worse like I did a few thing the test and in the past week it's gone from bad to worse..
2001 GT - True Blue
Old 07-25-2012, 07:05 PM   #7
i would suspect coil, pip/hall sensor or timing.
the coil and hall sensor can be tested and you can check your timing with a light.
Old 07-25-2012, 07:25 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Well it sounds like she's getting parked for the winter..
2001 GT - True Blue
Old 07-25-2012, 07:26 PM   #9
Why's that?
Old 07-25-2012, 07:27 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
I don't have the money to work on it any more..
2001 GT - True Blue
Old 07-25-2012, 07:29 PM   #11
Pete Jones
The pickup in the dist is actually pretty easy to change relatively speaking, I've done it once.
90 LX hatchback
89 LX Notchback
Old 07-25-2012, 07:29 PM   #12
Well testing parts is free. Once you figure out the problem go to the boneyard if you need to.
Old 07-25-2012, 07:41 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
What all do I need to test and ware can I take it?
---------- Post added at 08:41 PM ---------- Previous post was at 08:38 PM ----------
What and ware is the hall sensor is what I was getting at. Lol sorry just cranky now??
---------- Post added at 08:41 PM ---------- Previous post was at 08:41 PM ----------
Now...*
2001 GT - True Blue
Old 07-25-2012, 07:46 PM   #14
Coil
http://www.stangnet.com/mustang-foru...a-coil.334795/
Hall sensor test can be found in the useful mustang information sticky thread.
---------- Post added at 08:46 PM ---------- Previous post was at 08:45 PM ----------
The hall sensor aka pip is in/on the distributor.
Old 07-26-2012, 09:37 AM   #15
slow281
sixpac's Avatar
Region: Nebraska
Timing was retarded 15 degrees WTF
2001 GT - True Blue
Old 07-26-2012, 10:20 AM   #16
That would do it.
Old 07-26-2012, 10:39 AM   #17
slow281
sixpac's Avatar
Region: Nebraska
Who ever worked on this last is a fckn idiot
---------- Post added at 11:39 AM ---------- Previous post was at 11:26 AM ----------
That would do it.
Then I caped like 3 vacum lines
2001 GT - True Blue
Old 07-26-2012, 06:10 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
It still bogs down a little when I let off the gass? Any ideas
2001 GT - True Blue
Old 07-26-2012, 06:17 PM   #19
may just be in need of a good tune up.
fuel filter.
get some maf cleaner and throttle body cleaner and clean all the intake pieces and sensors. run some injector cleaner through it. make sure your plugs, wires, and cap, rotor button are in good shape. and clean out the egr.
12:06 PM
