Confused - Mustang Evolution
Old 07-28-2012, 11:33 PM   #1
Kenny laird's Avatar
Confused
Ny ideas y when i turn my lights on it makes my temp gage go up. Then turn lights off and goes back to normal Im baffled
Kenny laird is offline   Reply With Quote
Old 07-29-2012, 01:31 PM   #2
Re: Confused
Yes, your lights are way to hot.
It's probably an issue in the gauge panel.
It may be shorting out, remove it and check the back side for any issues with the wiring or circuitry.
There is a...... forgot the name of it, voltage regulator or resistor on the backside that should be adjustable. It may be your problem.
Old 07-29-2012, 01:34 PM   #3
On the back side of the gage cluster?
Old 07-29-2012, 01:48 PM   #4
Re: Confused
Yes - Gauge Cluster
Old 07-29-2012, 02:07 PM   #5
Is there a sertain seti g it should b at or do i just need to play around with it. I hate to keep takn it in and out
Old 07-29-2012, 02:21 PM   #6
Re: Confused
Read the article. I think it specifies setting it at 5 volts for instrumentation.
Old 07-29-2012, 02:29 PM   #7
Ok not sure what article u speak of but thanks for ur help ounce again
Old 07-29-2012, 02:56 PM   #8
Re: Confused
It is in the link I posted above. - Gauge Cluster
08:10 AM
