Stock 5.0 throttle body fit on GT 40 intake? - Page 2 - Mustang Evolution
Old 07-29-2012, 09:32 PM   #36
Originally Posted by 89Saleen141
Dang that looks good. I wish I would've thought of that when I had the alternator bracket already out. Gonna write that down as a future project to make my engine look a little tidier.
Thanx. Great stuff it is.
Old 07-30-2012, 07:57 AM   #37
Re: Stock 5.0 throttle body fit on GT 40 intake?
Originally Posted by JayKranz View Post
Here it is. Would I need a spacer or something between the upper and lower?
Attachment 61392
Attachment 61393
$90 is what he wants. That's not too bad.
---------- Post added at 08:38 PM ---------- Previous post was at 08:32 PM ----------
Should the intake have studs coming out where the throttle body and EGR spacer bolt on?
You only need the spacer if you are going to run the tall valve covers for rocker arm clearance. You will also want to block off the EGR holes if you are not using the EGR.
$90 is a bargain and you may be able to get it a bit cheaper if you explain to him it is just an Explorer intake and not a GT40?
Yes, there should be studs or bolts, but he may not have those.
Polishing would look great, but to do it properly to a mirror shine is going to take some time and lots of elbow grease.
I actually prefer a thin coat of black as it helps get rid of the heat a bit faster.
A rough polish and tinting with some of the Dupli-Color metal tinting sprays would look good too.
Old 07-30-2012, 11:37 AM   #38
88foxWarhorse's Avatar
This is a explorer intake however the explorers had what was call gt-40p heads and intake
And I believe I read in mustangs and fast fords
Magazine that the intake was support to flow better then The ones for the cobra
This is what I ran on my last mustang with stock heads and it ran good
88foxWarhorse is offline   Reply With Quote
Old 07-30-2012, 12:48 PM   #39
Yes, I know it is an Explorer intake and about the heads.
From the flow data I have seen it does not flow better than a Cobra intake, but it is close to it in flow capability.
While they work better than the stock intake and E7 heads, they still leave a lot on the table when compared to aftermarket heads and intakes.
I have had both and the difference is considerable.
Old 07-31-2012, 06:09 AM   #40
Then do you know if I take 93 cobra heads
And put the gt-40p intake on it will that work
Well together
Old 07-31-2012, 09:40 AM   #41
5.slow's Avatar
Region: Delaware
Those two should work together.
5.slow is offline   Reply With Quote
Old 07-31-2012, 11:16 AM   #42
93slowstang's Avatar
Well together
Yes it will work just fine.
06:51 AM
