Added my mods...now what? - Mustang Evolution
Old 07-31-2012, 07:15 AM   #1
AgPilot's Avatar
Region: Arkansas
Stock 87 gt 5 spd. Added trick flow street heat upper/lower intake, 65mm tb, maf and computer, msd, new 19lb injectors, cai. Bought but haven't added long tube bbk and h pipe. This car is for daily driving and Sunday drag racing. My get list are 3:73, subframe connectors, heads and cam. When I installed the intake a few days ago I didn't have the money for the heads or cam and now unexpectedly I do have the funds. Oh yeah I also got a 150-200 nos kit. My question is which aluminum heads and cam would be the best for my setup. What other mods do I need? Under drive pulleys a big help? Aluminum driveshaft? If I was to get a 331 stroker would my aluminum 302 heads fit it or not? Thanks alot.
AgPilot is offline   Reply With Quote
Old 07-31-2012, 10:13 AM   #2
Get list sounds good.
Any top brand heads will do the trick. I would make sure they have the upgraded flang to hold the head tight with the nos.
As for the cam. Once you decide on your heads and exact combo I would leave that to a professional. Having the right cam is key. And I'm sure a few guys will tell you what works good for them. But to get the most power I would leave it to an expert.
I would stray away from the ud pulleys also. Countless people on here have problems with them. Our cars don't take them very well. Almost everyone seems to have charging issues and even some have cooling issues.
I would also upgrage your injectors once you go stroked and hci.
A 331 is a 302. It just has different bore and stroke. So all bolt ons are the same
Old 07-31-2012, 02:21 PM   #3
AgPilot's Avatar
Region: Arkansas
Alright cool man thanks Alot. Hci? Heads cam intake? Heads are considered a bolt on?
Old 07-31-2012, 02:27 PM   #4
Yes hci= heads cam Intake
I'm not sure what others consider heads. But in my book they do bolt on. But what I was getting at is its the same motor with different crank, rods and the bore machined out.
And your welcome.
Old 07-31-2012, 09:19 PM   #5
Re: Added my mods...now what?
You have the Trick Flow intake, I would go with the matching Trick Flow heads and cam.Tell them you will be running nitrous and let Trick Flow choose. They will know what will work best for your combination.
12:28 PM
