my HCI swap - Mustang Evolution
Old 07-31-2012, 04:05 PM   #1
5.slow's Avatar
Region: Delaware
my HCI swap
Never did find time to start ripping into my car so I had to have someone else do it. Anyway, here are some pics of the tear down so far.
5.slow is offline   Reply With Quote
Old 07-31-2012, 04:15 PM   #2
its naked!
Old 08-01-2012, 05:12 AM   #3
5.slow's Avatar
Region: Delaware
Coming back together!!
Old 08-02-2012, 06:05 PM   #4
WhiteCobra94's Avatar
What HCI swap are you using?
Old 08-02-2012, 06:07 PM   #5
its hard to read the intake but looks like maybe holley intake and gt40p heads. just thought i would guess. cant see the cam though.
Old 08-02-2012, 06:16 PM   #6
Should put a set of 1.6 roller rockers on them heads!!!
Old 08-02-2012, 06:30 PM   #7
5.slow's Avatar
Region: Delaware
I have a set of 1.7s but I'm worried about ptv clearance. So putting the stockers on until I can find someone to trade for their 1.6s. It's gonna happen though.
Old 08-02-2012, 06:37 PM   #8
You should have checked ptv before you torqued the heads silly. Then you would've know if you could use the 1.7s.
Old 08-02-2012, 06:40 PM   #9
5.slow's Avatar
Region: Delaware
Budget build. Some p heads I got for $250. Fully ported upper and lower explorer intake I got combined with 70mm holly tb and 70 mm egr spacer all for $150. The cam is the e cam I got brand new for $50.00 from a guy who had it sitting on the shelf for almost a decade. Shopped around for a whole year for the best deals. Got a 75mm pro flow maf with 24 lb injectors for $80. Sold the injectors for $80 so maf was free. Bought a new set of 24lb injectors from a guy I work with for $75.00. Water pump, timing chain, 255 lph fuel pump all brand new. Just ordered an adjustable fuel pressure regulator for it. I'm excited to see how different it feels from stock when done.
---------- Post added at 08:40 PM ---------- Previous post was at 08:38 PM ----------
Also forgot putting in a new electric fan as well.
Old 08-02-2012, 06:59 PM   #10
What brand is the intake?
Old 08-02-2012, 07:05 PM   #11
Forum Car Trader
90GTNovi2000's Avatar
The difference over stock is gonna be a pretty good gain. But it won't blow your mind but that's the exact setup I had in my 85' w/ 1.6rr I made almost 280 rwhp with dyno tune
90GTNovi2000 is offline   Reply With Quote
Old 08-02-2012, 07:19 PM   #12
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I almost put a b cam in mine when I had the whole top end tore down but figured the wife would have been pissed then I found out she wouldn't have cared :banghead;
looks like a whole gt40 top end, I went with gt40p's and a Bbk SSI-r. Be careful of the wires and header clearance. I went with MSD 90 degree plug wires to avoid burning through my wires. I tried a heat sleeve on the one wire but it still melted until I switched the 90 degree ones.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 08-02-2012, 08:27 PM   #13
5.slow's Avatar
Region: Delaware
It's just an explorer intake but both upper and lower were ported including being opened up to match the 70mm tb.
Old 08-02-2012, 08:28 PM   #14
Nice
Old 08-02-2012, 08:33 PM   #15
5.slow's Avatar
Region: Delaware
I would be satisfied with that type of gain for this car. I want to get another one eventually and probably give this one to my wife.
---------- Post added at 10:31 PM ---------- Previous post was at 10:28 PM ----------
Thanks for the advice.
---------- Post added at 10:33 PM ---------- Previous post was at 10:31 PM ----------
I was considering the b cam too but I got the steal on the e cam so I went with that.
Old 08-09-2012, 05:29 PM   #16
5.slow's Avatar
Region: Delaware
Finally finished!!
Old 08-09-2012, 05:31 PM   #17
nice man. looks clean.
well how does it run?
Old 08-09-2012, 05:37 PM   #18
5.slow's Avatar
Region: Delaware
Way better throttle response than stock. Had an electric fan put on too. Cam sounds great. Next up is tranny swap. Only thing I am missing is a valve cover cap for one of the valve covers. Does anyone know where I can get one?
Old 08-09-2012, 06:03 PM   #19
for breathers ebay has huge selection. i got the driverside breather on ebay really cheap. it says mustang on it. i dont have a great pic of it handy but you can see it a little bit
Old 08-09-2012, 06:05 PM   #20
5.slow's Avatar
Region: Delaware
I have a nice Ford racing breather in the driver side but under the throttle body I can't fit a breather in there. That's the one I need.
---------- Post added at 08:05 PM ---------- Previous post was at 08:04 PM ----------
For the time being I put a rubber grommet in it from my hatch.
Old 08-09-2012, 06:06 PM   #21
still check ebay. i wanna say the selection was in the hundreds or thousands. but i dont remember for sure. if not i would just call summit racing and tell them what you need. they would definitly have what you need.
Old 08-09-2012, 06:12 PM   #22
5.slow's Avatar
Region: Delaware
Ok thanks for the help
Old 08-09-2012, 06:13 PM   #23
no problem.
Old 08-09-2012, 06:21 PM   #24
Forum Car Trader
Show another pic of you power steering DS
Old 08-09-2012, 06:26 PM   #25
5.slow's Avatar
Region: Delaware
Ok. Something look like it was put back together wrong?
Old 08-09-2012, 06:29 PM   #26
Forum Car Trader
Your good it looks great!!!!!! post a video when you can we want to hear it..
Old 08-09-2012, 06:33 PM   #27
5.slow's Avatar
Region: Delaware
Cool I will. It's in the garage now but I will be taking it out to clean it up for the American Muscle car show on Sunday. I'm not entered but I'm going.
07:19 AM
