-Battery cable - Mustang Evolution
Old 08-02-2012, 01:30 PM   #1
91notchback's Avatar
-Battery cable
Can anyone tell me where the negative battery cable is supposed to attach at? Mine is attached to the a/c support bracket. It won't start sometimes and you just have to loosen it and wiggle it around. Getting kind of old!
91notchback is offline   Reply With Quote
Old 08-02-2012, 01:36 PM   #2
Foxtrot's Avatar
I would clean a spot on the frame with sand paper to bare metal for a good connection then ground the batter to that spot and run a different ground for you engine to the frame
Foxtrot is offline   Reply With Quote
Old 08-02-2012, 02:18 PM   #3
Mine is hooked to ac delete, which used to be ac support. Like stated just make sure its nice and clean and tight.
Old 08-02-2012, 03:19 PM   #4
Re: -Battery cable
Leave it directly connected to the engine block to ensure a good ground for engine electronics, then run another ground to the frame.
I use bronze or brass internal star washers on each side of the wire end terminals to ensure a good ground.
The star washers bite into the metal on each side making really good contact.
Old 08-02-2012, 05:56 PM   #5
Jeff44's Avatar
I would also either clean or replace your positive cable. It looks in pretty bad shape. Also make sure you are making a good connection.
Jeff44 is offline   Reply With Quote
06:47 AM
