spark plug help!! - Mustang Evolution
Old 08-03-2012, 10:45 AM   #1
stangbanger92's Avatar
spark plug help!!
I just bought a set of autolite ar 3932 plugs for my 92 gt. Can they be used in a daily driver? And if so what gap?
stangbanger92 is offline   Reply With Quote
Old 08-03-2012, 10:49 AM   #2
deadsp0t's Avatar
Personally I use autolite 25's gapped at .54 I think..
That's unimpressive
Old 08-03-2012, 10:51 AM   #3
But will it tear anything up if i use them?
Old 08-03-2012, 10:52 AM   #4
deadsp0t's Avatar
Honestly have no idea.. Been using 25's for more then 10 years.. Sorry I can't be more help.
That's unimpressive
Old 08-03-2012, 11:26 AM   #5
Re: spark plug help!!
Just check them against what you are using or are supposed to use. If the depth and heat range are the same, then they will work.
Most plug sites have crossover charts and heat range information.
Old 08-03-2012, 08:46 PM   #6
5.8GT's Avatar
I think you have the wrong plugs, your car should take a ar25. Like Trojan said check them next to the plugs you take out. The ar3932 looks like it has a gasket seat and you car should have a tapered seat.
5.8GT is offline   Reply With Quote
Old 08-03-2012, 09:23 PM   #7
Good point. I never looked them up.
The 95 I owned previously had exactly that issue when I first got it.
They used the gasketed plugs on heads that were machined for tapered seats.
It ran a good bit better with the proper plugs.
09:38 PM
