Pulleys - Mustang Evolution
Old 08-05-2012, 03:22 PM   #1
Jbeas50's Avatar
Pulleys
Are these good pullys mr. Gasket
Jbeas50 is offline   Reply With Quote
Old 08-05-2012, 03:24 PM   #2
mr gasket is pretty reputable. but since those look like UD pulleys, be prepared for charging issues.
Old 08-05-2012, 03:31 PM   #3
Jbeas50's Avatar
Yea they are under drive pullys are they worth getting my buddy is selling them to me for 70
Old 08-05-2012, 03:36 PM   #4
i tell everyone to not get under drive pulleys. i has seen countless people on here have issues with them, including my self. they slow the alternator so much people usually have issues at idle. even with high amp alternators. imo they are not worth the hassle even if they were free.
Old 08-05-2012, 03:38 PM   #5
jdavis96gt's Avatar
Region: West Virgina
Re: Pulleys
Think foxes have charging problems with Udps due to small amp alternators. I could be wrong. You could always upgrade alternator too but that's not cheap.
Old 08-05-2012, 03:47 PM   #6
i still had problems after alternator upgrade. i went to a 150 amp. the problem is also the alternators are designed to spin a certain speed. i ended up keeping my pulleys except for the alternator pulley i switched out out for an overdrive. this totally defeats the purpose. but i didnt have my stock pulleys, plus the the new ones were prettier.
Old 08-07-2012, 09:11 PM   #7
WhiteCobra94's Avatar
+1 ..... I switched back to stock pulleys on my 94 after my motor swap, because of that!
Old 08-10-2012, 12:25 AM   #8
Re: Pulleys
Attachment 62372
They are ok pulleys, but....
....that and possible cooling issues....
....no, save your money a buy something more worthwhile and with less headaches.
Old 08-10-2012, 01:15 AM   #9
89 Foxloco's Avatar
So is their better pulleys than those or just stay stock pulleys??
89 Foxloco is offline   Reply With Quote
Old 08-10-2012, 01:35 AM   #10
Re: Pulleys
Stay stock and save yourself some headaches.
The issues they can cause are not worth the few HP you might gain.
You can realize as much or more HP recovery by installing a larger alternator and an electric fan, which may cost a bit more, but you'll get more benefits in return too.
Old 08-10-2012, 03:53 AM   #11
Travis B's Avatar
I currently have ud pullies and am wanting to go back stock. Where can I find a set of factory pullies?
Travis B is offline   Reply With Quote
Old 08-10-2012, 04:21 AM   #12
If your not having cooling issues but just charging issues you could overdrive the alternator leaving the ud crank pulley. This will get it spinning back the rpm it should. But besides that you will probably have to check salvage yards.
Old 08-10-2012, 04:47 AM   #13
Travis B's Avatar
I am currently BBC having cooling problems. It is fine going down the road but gets warm at idle.
Old 08-10-2012, 05:04 AM   #14
Yeah that's common also. So many people have problems with these damn ud pulleys. I don't know why Noone sells factory replacements.
Check rock auto, MPs auto salvage, and Emmet head auto (site sponsor)
12:03 PM
