91 gt won't go into gear - Mustang Evolution
Old 08-09-2012, 07:15 PM   #1
robert3188's Avatar
Pulled in the driveway and my car was fine. Went to move the car later n it won't go into gear. Def not the clutch cable. I can kinda jam it into gear n once its there I can go thru the gears.... Completely lost. Any helpd be appreciated.
robert3188 is offline   Reply With Quote
Old 08-09-2012, 07:21 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
Possible TB.. But crawl under and have someone pump the clutch to be 100% sure it's fully disengaging.
90GTNovi2000 is offline   Reply With Quote
Old 08-10-2012, 10:10 PM   #3
robert3188's Avatar
Ok... Took it apart. Clutch looked fine. Had 4 loose bolts. Everything else looked good. Put it back together n the clutch is about half as easy to push down as before.... Help!
---------- Post added at 11:10 PM ---------- Previous post was at 11:06 PM ----------
But still wont disengage so I can put it in gear...
Old 08-10-2012, 11:24 PM   #4
foxbox's Avatar
I had the same problem with my 92, my pressure plate broke and a piece of the plate wedged itself between the fingers of the pressure plate and clutch/flywheel. This caused the clutch to not disengage at all no matter how hard I pushed the clutch pedal down. I would just double check and make sure everything is still together.
foxbox is offline   Reply With Quote
Old 08-14-2012, 05:35 PM   #5
robert3188's Avatar
Thanks for the help guys. Seems the bushing that goes around the input shaft that the throwout bearing rides on on a tremec can come out of the flange and push against the clutch disc and hold it to the flywheel.... Hence the clutch not engagin... What a headache!
04:12 PM
