Drivers side window wont go up - Mustang Evolution
Old 08-10-2012, 11:56 AM   #1
Dtibbz22's Avatar
I drivers side power window 95 gt won't go up it clicks and comes up a little bit of I push the button sometimes not at all, all other windows work never had a problem before any idea?
Dtibbz22 is offline   Reply With Quote
Old 08-10-2012, 10:04 PM   #2
Re: Drivers side window wont go up
The little pins or balls in the regulator are busted up and not holding anymore.Get a window regulator repair kit and replace them if the motor is still good.
Old 08-10-2012, 10:33 PM   #3
Dtibbz22's Avatar
Did a little homework today came to a possible conclusion that armor all has gotten into the switch. Going to clean possibly replace while I'm in their. If this post is used for future reference and you have the same problem if u hit the driver side window switch interior lights will dim and radio will turn off. Also all windows will not allow you to put them up or down only after you hit the drivers side window switch. Their is no fuse for the windows. So basically u short the system until car goes off and on again to reset.
Window may go up or down maybe not at all. I tried dust off that worked to get it up but is not the solution.
Old 08-10-2012, 11:30 PM   #4
If the lights dim and the radio goes off that's an indication the regulator is grinding up the pins/balls like I said. You are over amping the motor when that happens and eventually you are going to blow a fuse or burn it or some wiring up. Armour All in the switch shouldn't cause that unless you just filled the switch up with it.
Old 08-11-2012, 12:21 AM   #5
Dtibbz22's Avatar
Autozone have a repair kit
Old 08-11-2012, 12:38 AM   #6
Kit
Old 08-11-2012, 02:31 AM   #7
Dtibbz22's Avatar
Thank you for everything pal
Old 08-11-2012, 07:23 PM   #8
You're Welcome & Good Luck with your project.
05:10 AM
