Oil pressure gauge - Mustang Evolution
Old 03-09-2008, 06:13 PM   #1
Scut95's Avatar
Oil pressure gauge
Does anybody know where the oil pressure sending unit is for the stock oil gauge? After I drive for a little my gauge drops below the L but i know it still has pressure, I would have starved the engine of oil and blew it already if not.
Old 03-10-2008, 12:24 AM   #2
MonteCitan's Avatar
Re: Oil pressure gauge
On the 92, it was drivers side of motor, front (below/behind your power steering pump)- on the block below the head
I don't see it being moved in a later year?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-10-2008, 07:20 AM   #3
starting in 96 the oil pressure gauge basically went to a switch that put the needle in the middle when the car has over 6psi of pressure (aka worthless) if your needle doesnt move when you are putting pressure on the engine (higher rpms) vs lower rpms its not doing much of anything.
Old 03-10-2008, 08:17 AM   #4
MonteCitan's Avatar
He still has a 5.0, so I'm pretty sure its the actual pressure gauge..
Old 03-10-2008, 11:19 AM   #5
It could be like my ranger is/was....I thought the stock gauge was lying to me so I hooked up an aftermarket gauge with new fittings. 40lbs at cold idle, 9lbs at warm idle, 7-8 lbs cruising down the highway in 5th.
Gotta keep that sucker revved up to keep from starving...
Old 03-10-2008, 12:24 PM   #6
Kiljosh's Avatar
Did not know that. The v6 and cobra too?
Old 03-10-2008, 01:51 PM   #7
Scut95's Avatar
I havent even been out on the highway with it, this is just crusin around town...but it drops belows the L like the gauge is malfunctioning.....i guess im gonna hafta do some tests, either that or blow it up goin home for spring break later this week, haha
Old 03-10-2008, 09:31 PM   #8
silverstangboy's Avatar
actually I believe the 5.0's had alot of these on/off pressure gauges as well. I can't remeber what year they started doing it though.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-13-2008, 01:29 PM   #9
MonteCitan's Avatar
with his reading the way it does, its not acting like an on/off switch, its not hard to replace the sending unit either way..
Old 03-15-2008, 02:53 PM   #10
Scut95's Avatar
Im gonna grab a cheap mechanical gauge while im home and see what the pressure actually is....maybe even replace the sending unit as well for ****s and giggles.....i have all week to figure it out.
Old 03-23-2008, 10:22 PM   #11
Scut95's Avatar
Well i finally got some gauges in, and the pressure seems to be ok so im thinking the sending unit was going bad.....anybody know the pressure range the 5.0 is supposed to have?
Old 03-23-2008, 11:45 PM   #12
MonteCitan's Avatar
Mine's around 45-50 hot idle, 55-60 hot cruise/WOT but high volume pump...
Old 03-24-2008, 07:08 AM   #13
my damn 01 v6 was at 75 about all the time accept for right at idle where it would sit around 30ish~
NO OIL PRESSURE bmxrr1990 Pre-2005 V6 Mustang 11 11-23-2009 10:04 PM
oil pressure help jesse4887 1979-1995 Mustang GT 25 06-01-2007 10:39 AM
Extra oil pressure sender unit for press gauge wesoakes Pre-2005 V6 Mustang 10 11-19-2006 12:57 PM
Oil pressure going crazy Zim Pre-2005 V6 Mustang 9 11-17-2004 10:28 PM
04:45 AM
