OBD2 port on a 94 gt? - Mustang Evolution
Old 08-12-2012, 10:35 AM   #1
94GT302's Avatar
Was running stereo wires on my pony and there is a OBD2 port on the drivers side under the dash. What's this port for? I couldn't get my snap on scanner to read from that port (thought it was worth a try)
94GT302 is offline   Reply With Quote
Old 08-12-2012, 11:55 AM   #2
Re: OBD2 port on a 94 gt?
Pretty sure it is a test port, but it is not an OBD II port, so trying to use an OBD II tester will not work. It is an OBD I port, I believe.
Old 08-12-2012, 03:21 PM   #3
94GT302's Avatar
I knew it wasn't a diagnostic port. Just curious what type of tests would you use this port for?
Old 08-12-2012, 03:31 PM   #4
Ok, here is what I found on the net.
The dash harnesses between the 5.0 and the V6 for 94/95 were similar and used in either model. However, that connector is for OBDII computers and IS functional only in the 94-95 V6 for extracting codes. The 94-95 V6 Mustang was already OBDII compliant.
Old 08-14-2012, 11:17 AM   #5
94GT302's Avatar
Awesome that's helpful info thanks
Old 08-15-2012, 09:04 AM   #6
But didn't some late 95 come with odbII and if so cane u convert a 95 to a odb2
tbonestang is offline   Reply With Quote
Old 08-16-2012, 09:27 AM   #7
What I found said the V6's are, but nothing indicated the V8's had a functioning OBDII port, just that it may be present on the vehicle as they used the same wiring harness as the V6.
Old 08-16-2012, 09:33 AM   #8
yea ODBII is not until 96 so it was ODBI in 94/95
12:08 PM
