True duals or c pipe - Mustang Evolution
Old 08-12-2012, 06:58 PM   #1
Dtibbz22's Avatar
Recently ran true duals with cats ( went to a muffler shop instead of my mechanic that's why cats are on) Anyway I'm getting them taken off and thinking about an x pipe. What's a better option here in terms of over kill to the muffler (flowmaster 40 series are on now) also will I need heat shields where the cats used to be
Dtibbz22 is offline   Reply With Quote
Old 08-12-2012, 07:55 PM   #2
Re: True duals or c pipe
True duals are or should be a thing of the past.
An H or X-Pipe works better and sounds better too IMO.
Their purpose is to smooth out the exhaust pulses which promotes a better flowing exhaust system.
You won't need heat shields where you remove the cats unless the exhaust runs really close to something that needs shielding. The cats build a lot more heat than a straight piece of pipe.
Old 08-12-2012, 08:06 PM   #3
Dtibbz22's Avatar
Ran true duals because I figured it would be easier to change. Anyway I would like to do an x pipe, however should I go smaller in diameter for back pressure without cats so I don't get that motorcycle sound at higher RPM. Or stay equal and/or greater then the piping now. I'm also thinking bolt on instead of welds for future dump outs.
Old 08-12-2012, 08:26 PM   #4
No do not go smaller you don't need the back pressure.
Run 2.5" pipe.
There is an article on exhaust in the Useful Info thread.
Old 08-12-2012, 08:30 PM   #5
Yeah 2.5 and u could use 3" tips
Old 08-16-2012, 07:19 PM   #6
Dtibbz22's Avatar
Anyone know if running true duals with no cats is harmful. I found out that heatshields don't like them with cats.
Old 08-17-2012, 09:22 AM   #7
jacob.a.gasparp's Avatar
Region: Nebraska
My 89 has true deals without cats on them and it runs fine as long as the o2sensors are still there. I'm gonna do a x pipe someday too.
jacob.a.gasparp is offline   Reply With Quote
Old 08-17-2012, 05:27 PM   #8
93slowstang's Avatar
Running divorced pipes hurts performance. Even with a crossover mid pipe it is still "true" duals. The crossover helps balance the exhaust and creates velocity getting rid of unnecessary back pressure.
---------- Post added at 06:27 PM ---------- Previous post was at 06:24 PM ----------
You would be better off cutting them out.
06:30 AM
