95 mustang gt does not need to pass emissions in massachusetts however if a dash light is on it is automatic fail. If I take my cats off will check engine light come on? Pre- obd II
Kinda my thinking....,of you don't have to pass emissions why do you have to take the test and get a sticker? :confused;mymustang said:If it doesnt have the o2 after the cat you should be fine..Which is pre obd2..How is it automatic fail if you dont need emmision??
I talked to my mechanic and obd II cars throw a light code so you should get your sticker then take them off until you figure out how to shut the check engine light off. The only light you can have on at a MA inspection is abs and probably (battery light)Adogg said:I also live in mass and the law is any car before 1997 does not have to pass emmission test but can not have smoke coming from tailpipes (good oil change) and must pass safty and visual inspection and iam getting and h pipe put on monday and hopefully will still pass (also have the air bag light) there are some tunes that can make your o2 censors to stop throwing the code.
I got my h pipe on there today and it has not thrown any codes yet i have a 94 gt (obd1)Dtibbz22 said:I talked to my mechanic and obd II cars throw a light code so you should get your sticker then take them off until you figure out how to shut the check engine light off. The only light you can have on at a MA inspection is abs and probably (battery light)
On board diagnostics it is the way u can scan your car for codesRobbiemustang96 said:wat does obd mean
Well some times your ecu can store codes you can reset ue ecu and see if it come backRobbiemustang96 said:ohhhh ok my engine light is also on but it runs great
Yes i would leave it off for like 10-30 if u have nothing to do i would say 30Robbiemustang96 said:how do you reset it disconnect the negative side of the battery? for how long
minutes? does it take that long well i guess it isnt a phone haha ok i can try that on saturdayAdogg said:Yes i would leave it off for like 10-30 if u have nothing to do i would say 30
Just to let you after you do it your engine will go through a re learning process might run wierd but will fix it self and then will run better then everRobbiemustang96 said:minutes? does it take that long well i guess it isnt a phone haha ok i can try that on saturday
It wont run crappy just wierd you wont notice it that bad and you should drive it for around 10 miles and it will relearnRobbiemustang96 said:like how crappy and how long will it take to relearn
