Clutch cable - Mustang Evolution
Old 08-14-2012, 07:49 PM   #1
Scottnos1's Avatar
Clutch cable
I have a 93 stang and every year I've had to replace the cable I've tried heavy duty , adjustable and every year it snaps or stretches out . I also had the transmission rebuilt 1 1/2 ago and it's not the throw out bearing so what do I do
Scottnos1 is offline   Reply With Quote
Old 08-14-2012, 07:51 PM   #2
Dtibbz22's Avatar
Don't know if this is possible but in theory could you run two cables
Dtibbz22 is offline   Reply With Quote
Old 08-14-2012, 07:52 PM   #3
have you tried the factory cable? it is the strongest
Old 08-14-2012, 08:34 PM   #4
Scottnos1's Avatar
No I haven't but wouldn't a heavy duty one be just as good if not better
Old 08-14-2012, 08:35 PM   #5
the best cable is a factory one. very common problem with aftermarket cables breaking and stretching. i think maximum motorsports uses oem cable. try them.
Old 08-14-2012, 08:41 PM   #6
Scottnos1's Avatar
Don't think that's possible , don't have the room
---------- Post added at 09:41 PM ---------- Previous post was at 09:35 PM ----------
That's funny u say oem because I went down to ford today and they wanted to charge me $ 400 and aftermarket was $120 BBK cable do u no how much it is from maximum
Old 08-14-2012, 08:49 PM   #7
not sure but wow. 400$ is crazy. check AM
---------- Post added at 09:49 PM ---------- Previous post was at 09:42 PM ----------
here, this is what you want. http://www.maximummotorsports.com/st...roducts_id=385
also make sure you arent over adjusting your cable.
Old 08-14-2012, 08:50 PM   #8
Scottnos1's Avatar
Ya asked if it was made out of gold I'll look in to it more tmrw thanks
Old 08-14-2012, 08:51 PM   #9
no problem man. if that cable breaks then you have issues.
Old 08-14-2012, 08:52 PM   #10
foxbox's Avatar
You could get a hydraulic clutch at that rate lol
foxbox is offline   Reply With Quote
Old 08-14-2012, 08:57 PM   #11
Scottnos1's Avatar
Thought about that but my local speed shop wanted to Charge me $700
Old 08-14-2012, 10:16 PM   #12
Kenny laird's Avatar
I had nothing but probs with stock cable it would break after two or rhree timees pushing clutch in. Bought a aftermarket from summit have had a prob sense
Kenny laird is offline   Reply With Quote
Old 06-21-2014, 04:30 PM   #13
Scottnos1's Avatar
I have a 93 GT . What should my oil pressure be at idle
Old 06-22-2014, 04:37 PM   #14
smurf stang's Avatar
Well Scott did you ever fix the clutch cable issue?
How many miles on your motor?
What kind of oil gauge are you using?
2016 VW GTI 2.0 Turbo
Old 06-22-2014, 08:56 PM   #15
Horray for thread necro from 2012...
Old 06-23-2014, 12:13 PM   #16
Funny thing is he started this thread about clutch cable 2 years ago.
Never posted the outcome.
Now starts a new thread on his old thread and hijacks his own thread.
Old 06-23-2014, 10:13 PM   #17
Scottnos1's Avatar
Old 06-23-2014, 10:21 PM   #18
Scottnos1's Avatar
Sorry not really a computer guy . So it turns out my ground wire from the engine was off and grounding out on my clutch cable which was heating it up then cooling off making it brittle and my headers were melting the sheathing and sticking to the cable and in the end I crushed my fire wall from the pressure.
Old 06-23-2014, 10:24 PM   #19
Scottnos1's Avatar
I have 165 000 km.
auto meter gauge
Old 06-24-2014, 01:15 PM   #20
What does it read psi when warm at idle?
Old motor kinda tired maybe high teens.
low 20's to low 30's is ok for a used motor.
Also depends on your oil weight.
Old 06-24-2014, 03:32 PM   #21
Scottnos1's Avatar
It reads around 15 psi give or take a couple but when I put my foot in it , it reads around 60 psi
Old 06-24-2014, 06:15 PM   #22
Is it burning oil?
Smoking a little?
What weight of oil are you using?
You could try something heavier.
Also a compression and leak down test will explain some.
---------- Post added at 08:15 PM ---------- Previous post was at 08:15 PM ----------
Is it burning oil?
Smoking a little?
Old 06-24-2014, 09:03 PM   #23
Scottnos1's Avatar
I decided to just take it to my buddy's shop . I've had a bite of a tic in my heads so I'm just gonna check every thing all at one .
Old 06-25-2014, 11:18 AM   #24
Definitely report back and let us know your findings.
04:10 PM
