Throwout bearing - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Old 08-16-2012, 03:37 PM   #1
94GTpony's Avatar
94GTpony is unknown around these parts
Throwout bearing
I I have a 94 gt 5.0 and I was told the clutch was just replaced about 5,000 miles ago. It seems that the throw out bearing it messed up already. With a little squealing until pressure is put on the pedal. Is it smart to just replaces the whole clutch instead of just the throw out bearing? Thanks
94GTpony is offline   Reply With Quote
Old 08-16-2012, 03:47 PM   #2
Senior Member
dreamstang is unknown around these parts
if the clutch only has 5k on it then it shouldnt need replaced.mwhen uou take it off you should be able to tell. to me it sounds like it wasnt adjusted properly and the tob was riding against the pressure plate. it will burn up really wuick if this happens. it should only make contact when engaging the clutch.
Old 08-16-2012, 03:50 PM   #3
94GTpony's Avatar
That's what I figured but I didn't want to rip all that apart put a new throw out bearing in and a couple months down the road something be jacked up with the clutch. Thanks for the input bc I was stuck on what to do.
Old 08-16-2012, 03:51 PM   #4
Senior Member
as long as it isnt worn then it should be fine. also may not hurt to usema heavy duty tob.
Old 08-16-2012, 03:52 PM   #5
94GTpony's Avatar
I'll ride in 1-3rd gear or so and it will squeal a little until I go to change gears or put alittle pressure on the pedal and it goes away but I don't want to "ride" the clutch.
---------- Post added at 04:52 PM ---------- Previous post was at 04:52 PM ----------
Thanks for the input.
Old 08-16-2012, 03:54 PM   #6
Senior Member
if you cant get it adjusted so it doesnt ride on the pressure plate, then there is a mod located in the stickies section with a fix.
and your welcome.
05:53 PM
