engine troubles - Mustang Evolution
Old 03-13-2008, 08:15 AM   #1
engine troubles
Can anyone tell me why my mustang bogs down when I let off the gas and then bogs down and slams when I get back in the gas? It's annoying the hell out of me. I have an 87 GT 5.0
Bill O. is offline   Reply With Quote
Old 03-13-2008, 01:33 PM   #2
MonteCitan's Avatar
Re: engine troubles
Perhaps you'll find more help in the 5.0 forum, moved your thread here-
Can you describe this any better?
When you're at a stop and hit the gas to start accelerating, does it act normally?
Does it shift normally except for when you're already moving then you let off the gas/try to get back onto it?
What speeds and in what gears does this issue occur most with?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-13-2008, 09:58 PM   #3
silverstangboy's Avatar
Re: engine troubles
sounds like its going lean momentarily in decel fuel tables.. many reasons why this happens, tell us more, do a KOEO and a KOER test if possible, look it up if you don't know what those are.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-14-2008, 10:42 AM   #4
Re: engine troubles
Old 03-14-2008, 11:01 AM   #5
Re: engine troubles
Thanks for the replies. It does do it when I am at a stop an hit the gas. It bogs down and sometimes stalls. It shifts normally through the gears but sometimes downshifts erratically. It occurs at just about any speed and in any gear. It is felt most at highway speeds between 45 and 75 m.p.h. It acts like its starving for fuel or air so asa precaution I changed the air and fuel filters. I thought I might have a dead spot in my TPS but did a sweep on a scope and it's ok. The problem did not come on gradually it kind of just appeared. Thanks for the help
Old 03-14-2008, 10:15 PM   #6
Re: engine troubles
well, I believe I'd still do KOEO and KOER test, then i'd consider taking it to a tranny shop to let a tech drive it.
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure hopefully brent doesn't mind the link to another site, it is good tech, used this to diagnose plenty of cars.
93 mustang notch
Old 03-15-2008, 05:56 PM   #7
Re: engine troubles
thanks silver I was hopin it wasn't a tranny problem. I figured it may be. Thanks for the help
Exhaust Troubles. Help Please Dark04ShadowV6 2005-2010 Mustang GT 3 05-07-2009 06:21 AM
Ghia troubles GhiaGirl Classic Mustangs 1 08-21-2006 07:26 AM
Engine troubles electricstang99 1979-1995 Mustang GT 2 07-06-2005 01:40 PM
Headlight Troubles xtremestang Mustang Audio & Video 14 11-06-2004 06:08 AM
Relationship troubles. MusclesFromBrussels The Bar 3 07-19-2003 02:42 PM
01:04 AM
