Well I finally got my motor back together and fired it up for the first time friday night and damn it sounded mean. I had everything set and she fired right up, to my amazement, lol. Guess i did a lil something right. Anyway, it ran for maybe 5 mins then died and wouldn't start back. I have researched and done test that pt toward the pip going bad. Whats the odds of the pip going out like that? It ran fine before i do the rebuild. Only thing different was add maf and computer. Any help is greatly appreciated!
How was the Maf and the computer added in? was it a complete wiring harness that came with the MAF and computer or did you have to move pins in the connector for the computer and do some splicing? if you had to move pins I would check that first and make sure the pins were locked in well.
Yeah i had to splice and move a couple wires. I did solder the ones that were spliced and the wiring harness came with the 2 pins connectors and i used them. I will go out in a few and check it all again though
Yeah i have run a few electrical test and if i did it right then its pointing to the pip being bad but before i change ima try the tfi module from my brothers ford. If that don't fix it then i will take the whole distributor. I won't have to buy them parts right off so it helps having the spares to try first. I will look thru the stickies to read and double check. Thanks
Don't forget the TFI module needs the heat transfer paste under it or they won't last long. So make sure you have some handy to re-install it on his vehicle. Trying to get by without replacing the paste just won't work.
I know mine looks like the top one and i hope that other is the same then. I will get some good heat paste to. I sure rather have it right then fry something. Lol Thanks for looking out trojan!
Thanks trojan. When i make the video i will surely put up the link for it!
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
