throttle cable hung up? - Mustang Evolution
Old 08-20-2012, 07:56 PM   #1
5.slow's Avatar
Region: Delaware
Can the throttle cable get hung up or run out of cable if you put on a 1" intake spacer? The tb is not going all the way back to the adjustment screw and I'm not sure if the cable is getting hung up or if its the tb.
5.slow is offline   Reply With Quote
Old 08-20-2012, 08:58 PM   #2
you habe any pics? im having a little trouble understanding the problem fully.
if you need more slack check under the dash if you can pull a little through.
if you are trying to set idle then you need to follow the proper procedure and not just turn the screw.
Old 08-20-2012, 08:59 PM   #3
Re: throttle cable hung up?
If you stretched out the cable it could be that it is just to short, but I have not heard of that happening with a 1" spacer.
Otherwise yes, they can get burs in them and hang up.
Old 08-20-2012, 09:40 PM   #4
5.slow's Avatar
Region: Delaware
I did attempt to set the idle with the proper procedure but it wouldn't matter because the cable won't even rest against the adjustment screw even when idling unless I force it back. I'm going to begin by disconnecting the throttle cable and see if its still hanging up. If so I will clean the tb and go from there. If it doesn't work I will post a pic. Thanks for the help.
Old 08-21-2012, 04:07 AM   #5
sounds like a good starting spot.
Old 08-21-2012, 06:49 AM   #6
5.slow's Avatar
Region: Delaware
I haven't had a chance to look at it yet but here is a photo that I snapped on the way out the door to work today. This is with the car off.
Old 08-21-2012, 06:51 AM   #7
5.slow's Avatar
Region: Delaware
Also the cruise control cable had to be removed to clear the tall valve covers. Could that be what is causing it?
Old 08-21-2012, 03:05 PM   #8
Attachment 64866
The more important thing is, is the throttle plate closed?
The screw not touching the linkage may or may not mean anything.
Old 08-21-2012, 08:34 PM   #9
5.slow's Avatar
Region: Delaware
My chilton manual talks about plugging a hole in the plate with the appropriate color plug if idling too high. Maybe my new(used) tb needs to have the hole restricted to idle properly?
Old 08-21-2012, 09:37 PM   #10
Maybe so. Does the plate close completely or not?
Old 08-22-2012, 01:22 PM   #11
5.slow's Avatar
Region: Delaware
Sorry for the late reply. Been busy with my kids. This photo shows the tb plate with the ignition off in its resting position.
Old 08-22-2012, 03:36 PM   #12
Plugging a hole in what plate?
Attachment 65064
Ok, it does not appear to be fully closed.
Is the cable holding it or is it binding on something else?
Old 08-22-2012, 08:11 PM   #13
5.slow's Avatar
Region: Delaware
I don't know. Maybe the stock tb had a hole in the plate? Or maybe I misunderstood it. Anyhow, I will try to take a look at it tomorrow night. I havent disconnected the throttle cable yet. When I do I will post another pic of the throttle plate.
Old 08-22-2012, 08:28 PM   #14
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Are you putting the cable in the right hole? Tgeres a throttle cable hole then there is also a kickdown cable hole for the aod tv cable
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 08-22-2012, 09:34 PM   #15
Ok, the more pics of the TB, plate & linkage you can get, the easier it will be for us to help you determine what is wrong.
Old 09-05-2012, 01:26 PM   #16
5.slow's Avatar
Region: Delaware
Finally got the car to idle around 900-1000 rpm but still didn't like how the car ran with the aod and no stall converter with my cam so I decided to just go ahead with the t5 swap now. It's in the process and I will let you know how it runs when its complete.
03:41 AM
