swap help - Mustang Evolution
Old 08-21-2012, 06:34 PM   #1
Redsteel's Avatar
swap help
Ok this thread is for 5 speed swap help for yours truly. I need to get it done soon and I am running into problems. The stickies helped but I need some details now.
1. I got a stock clutch cable. Where does it bolt to the firewall? I see no holes around the place the cable comes through at.
2. Speedometer cable is getring switched and it didn't come with instructions. Any advice or links to instructions would be greatly appreciated.
As I run into problems or snags I will post questions here. Thanks very much.
Redsteel is offline   Reply With Quote
Old 08-21-2012, 07:28 PM   #2
Re: swap help
Clutch Cable 1 - This is on a newer Mustang, but it should work the same as yours.
Clutch Cable 2 - Adjustable cable installation.
Speedo Cable
Speedo Cable Info
Old 08-31-2012, 02:33 PM   #3
Redsteel's Avatar
That helped a lot trojan. I've been workin a lotta hours both on my fox and at work. Tonight should be 99% completion of the stang, all but a midpipe. Mine was falling apart. Any suggestions on one? I had a 2.5 inch mac.
Old 08-31-2012, 04:00 PM   #4
Re: swap help
I would just use 2.5" mid-pipes. I had some trouble finding one for one of my Foxes some time ago, and I don't remember where I finally found just the mid-pipes, but they are available. Check with our sponsors, American Muscle, I bet they can find you what you need.
Old 09-06-2012, 08:03 AM   #5
Redsteel's Avatar
Pulled the trigger on a 2.5" bbk O/R h pipe. Should be here tomorrow or Monday.
Finishing the car up tonight hopefully my connections are all good and I can fire her up.
Old 09-12-2012, 12:57 PM   #6
Redsteel's Avatar
Is the reverse light harness the same on the sn95 and foxes?
Old 10-01-2012, 11:53 PM   #7
Redsteel's Avatar
Went ahead and pulled the dash the other day to change my heater core as its the original one. Got sidetracked and ended up having to wait a couple days to put tge dash back in. Now I've got a couple plugs I can't account for.
Two are single plugs with black/yellow wires, and attached is a picture of the other. The car is a 91 hatch, original 5.0. Thanks guys
02:31 PM
