Car sometimes dies When i put it in drive or reverse - Mustang Evolution
Old 08-23-2012, 07:39 PM   #1
Drgula5's Avatar
After running my 95 ill turn it off.. Then after about a half hour or so, ill start it up put it in drive or reverse and it will idle low then die... Could it b bcuz of my afterdrive pulleys? Or pip?
Drgula5 is offline   Reply With Quote
Old 08-23-2012, 08:42 PM   #2
Drgula5's Avatar
Bump... Anybody??? Surely somebody has had tve same prob....
Old 08-23-2012, 08:45 PM   #3
not sure on this one buddy. the pip is testable though. there is a link in the useful mustang information stickies thread.
Old 08-23-2012, 09:05 PM   #4
Drgula5's Avatar
I knew u would come thru dreamstang... It doesnt happen all the time... Thats why i was wondering if it was just tbe underpulleys when i start it up and didnt get quite the rpm's... Other than that... My engine is REALLY STRONG....
Old 08-23-2012, 09:08 PM   #5
The only thing the pulleys would affect are charging and cooling. But its possible charging issues are the culprit, but kinda doesn't sound like it. You can test your battery hot and cold, running and not running. You should have 12.5 volts off and 14.5 volts running. I hate ud pulleys. Everyone has issues with them.
Old 08-23-2012, 09:15 PM   #6
Drgula5's Avatar
So do u think i should change tge distributer which is a common prob with the pip on sn 95's?
Old 08-24-2012, 03:51 AM   #7
Not before following the proper test procedure.
Old 08-24-2012, 04:44 AM   #8
WhiteCobra94's Avatar
Fuel pump, low voltage ..... Etc
02:10 PM
