1995 GT Cam won't turn - Mustang Evolution
Old 08-24-2012, 10:13 PM   #1
TheLast5.0's Avatar
Cam gear bearing? Timing cover is off, distributor off and when i tightened the cam it doesn't turn the cam. The cog behind it isn't turning. Did the bearing seize?
TheLast5.0 is offline   Reply With Quote
Old 08-24-2012, 10:20 PM   #2
TheBandit's Avatar
Re: 1995 GT Cam won't turn
Can you turn the crank? and is the timing chain still on?
TheBandit is offline   Reply With Quote
Old 08-24-2012, 10:45 PM   #3
With the chain still on you will not be able to turn it.
With the valve train still in place, it will be difficult to turn if you can turn it at all.
With everything disconnected and it won't turn, then likely a bearing has seized.
Old 08-24-2012, 10:50 PM   #4
Filibuster
Even if you take the timing chain(gear) off the valve train is still holding the cam in place.
XXSTEVEO66 is offline   Reply With Quote
Old 08-25-2012, 09:45 AM   #5
TheLast5.0's Avatar
Yea timing chain is off. Evidence is pointing to the bearing seized. $25 part and hours of labor lol.
Old 08-25-2012, 09:56 AM   #6
But the valve train is still on? I would unbolt the rockers first to be sure, as you will have to anyways.
Old 08-25-2012, 06:26 PM   #7
May be worse than that if it damaged the cam and/or block.
Old 08-25-2012, 07:42 PM   #8
TheLast5.0's Avatar
Cam was damaged. Bought a timing chain set w/cam and cam bearings. Hopefully tearing into it tomorrow to further investigate
Old 08-25-2012, 07:46 PM   #9
Let us know what you find and some pics would be nice for future references if you can get them.
Old 08-25-2012, 08:08 PM   #10
TheLast5.0's Avatar
Ugh. Lol. I will take them tomorrow!
Old 08-29-2012, 01:23 PM   #11
TheLast5.0's Avatar
Welp, getting a different motor. 302 Cobra here i go.
12:10 PM
