high idle - Mustang Evolution
Old 08-27-2012, 10:22 AM   #1
high idle
95 5.0 cobra engine racing kicks down to 1200rpm sometimes dont start also engine shakes
davep is offline   Reply With Quote
Old 08-27-2012, 02:23 PM   #2
Jeff44's Avatar
Sounds like a fuel problem. Did you change your fuel filter? If its fuel injected, check your injectors.
Jeff44 is offline   Reply With Quote
Old 08-27-2012, 02:39 PM   #3
Forum Car Trader
90GTNovi2000's Avatar
Or tps.. Check the sticky thread on testing procedures or reference a Chilton or Haynes manual..
---------- Post added at 03:39 PM ---------- Previous post was at 03:37 PM ----------
If the engine is shaking it sounds like a miss.. Check all your plug wires make sure they are all on good at the distributor and plugs and coil, also look for burnt or melted wires that may be jumping arc onto a nearby header or metal surface.
90GTNovi2000 is offline   Reply With Quote
01:48 PM
