Anyone familiar with the 92 rustangs airbag systems? - Mustang Evolution
Old 03-18-2008, 06:20 PM   #1
MonteCitan's Avatar
Had to slam on the brakes a while ago to avoid someone coming into my lane
almost immediately after, the airbag light began flashing at me
Flashed 4, pause, 6 pause...
so code 46
What I found online was 46 | LH front crash sensor not mounted to vehicle properly | P
It seems to be securely mounted but could something be loose inside making it think it's not mounted? It doesn't flash every time I take it out, sometimes only if I'm beating on the car a bit..
any ideas?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-18-2008, 07:26 PM   #2
silverstangboy's Avatar
Re: Anyone familiar with the 92 rustangs airbag systems?
they're are a few connectors for it that could be loose, its just an EOL resistor system... I'd take the battery off for serveral hours and then clean all of the white connectors at the passenger side inner fender under the hood.
did you check veryuseful.com? anyways, if that doesn't do it i'd look around at the junkyards, those sensors will degrade after time from vibration and heat.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-18-2008, 09:59 PM   #3
MonteCitan's Avatar
Yeah I found that info at veryuseful, but no pinpoint test P was available
Old 04-12-2008, 07:32 AM   #4
I would figure, a pinpoint test would make me nervous if I posted it, due to crazies and their lawyers and such.
so did you figure out what was wrong?
93 mustang notch
Old 04-12-2008, 08:11 AM   #5
MonteCitan's Avatar
It's alright, I found it posted on the web
Its' too intermittent to find the problem I guess, the connections are all good, the sensor IS mounted fine, the wiring had no issues with continuity.. That's as fas as I got then I buttoned it back up and came back up to school, so I haven't had a chance to work on it yet, and I likely won't til I get back from cali in August
HP Estimates? not too familiar with 5.0 Scorpion1 The Bar 3 02-21-2010 07:58 PM
airbag light customsixstang Pre-2005 V6 Mustang 7 01-10-2008 05:01 PM
Airbag on a motorcycle.. MonteCitan Pictures and Videos 5 02-02-2007 02:49 PM
airbag power question WhiteStang99 Pre-2005 V6 Mustang 10 06-12-2004 12:35 AM
Airbag Question v6mustangguy Mustang Audio & Video 34 01-22-2004 05:08 PM
05:56 AM
