Spinning noise after clutch install. - Mustang Evolution
Old 08-31-2012, 02:00 AM   #1
sam13708's Avatar
Region: Oregon
was wondering if anybody knows if it's normal that I can still hear a spinning noise when accelerating.. I just replaced the clutch about a month ago.. Centerforce stage 1.
sam13708 is offline   Reply With Quote
Old 08-31-2012, 02:45 AM   #2
McNassty's Avatar
Did you buy the Centerforce H/D throwout bearing?
McNassty is offline   Reply With Quote
Old 08-31-2012, 09:50 AM   #3
sam13708's Avatar
Region: Oregon
ya a got a new throw out bearing.
Old 08-31-2012, 10:16 AM   #4
you need to make sure the tob isnt riding on the pressure plate when the clutch isnt engaged.
Old 08-31-2012, 04:25 PM   #5
Re: Spinning noise after clutch install.
There is a fix for that issue in the Useful Info sticky thread.
Old 08-31-2012, 10:08 PM   #6
sam13708's Avatar
Region: Oregon
how do I get to the useful info thread?? can't find it
Old 08-31-2012, 10:13 PM   #7
If you are using the app, click on the stickies section located on the top of the screen. On the right side next to where it says threads.
Old 08-31-2012, 10:30 PM   #8
sam13708's Avatar
Region: Oregon
thanks, found it. read the whole thing but didn't find out about why I can hear my flywheel spinning while accelerating.
Old 08-31-2012, 10:37 PM   #9
Trojan was referring to this. It's called something like clutch freeplay mod. It won't help you identify the problem but if its what I described, it will help fix it. That is if the tob is riding on the pressure plate fingers when the clutch isn't engaged. You should be able to pull the cover off by the fork and see if that's your proble..
How to make your own clutch freeplay kit
04:30 PM
