Gaskets - Mustang Evolution
Old 08-31-2012, 05:38 PM   #1
Jeff44's Avatar
Gaskets
When installing the upper intake manifold, do I need to put sealant on the gasket or should I put it in dry? If sealant is needed, what do you prefer?
Jeff44 is offline   Reply With Quote
Old 08-31-2012, 05:39 PM   #2
I do dry
JayKranz is offline   Reply With Quote
Old 08-31-2012, 05:50 PM   #3
Forum Car Trader
90GTNovi2000's Avatar
Dry only
90GTNovi2000 is offline   Reply With Quote
Old 08-31-2012, 06:17 PM   #4
Jeff44's Avatar
Thanks guys!
Old 08-31-2012, 06:53 PM   #5
Re: Gaskets
Depends on the gasket material.
If it is a Fel-Pro that is coated, then nothing is required.
If it is a paper gasket, then I will spray it with Permatex Copper Coat or wipe it with a thin layer of silicone to ensure a good seal.
Old 08-31-2012, 07:13 PM   #6
And if your doing the lower also you need to toss the end gaskets. And use a 1/4" bead all the way across and overlap onto the heads area.
Old 09-01-2012, 06:04 AM   #7
Jeff44's Avatar
Thanks. Also there is a vacuum hose coming off the oil filler tube (vent) going to the upper intake manifold and from the upper intake manifold going to the vacuum tree but I noticed no hose going to the PCV valve. Should there be a hose going to that and if so where does it connect to?
Old 09-01-2012, 12:55 PM   #8
Re: Gaskets
Old 09-01-2012, 03:36 PM   #9
Jeff44's Avatar
Thanks Trojan. I put the manifold on and forgot to connect to the PCV valve. SMH!
Old 09-02-2012, 09:27 PM   #10
Re: Gaskets
**it happens!
09:20 PM
