94 mustang gt help - Mustang Evolution
Old 09-02-2012, 10:33 PM   #1
Slow94GT's Avatar
94 mustang gt help
Hey guys, first post here. Im 17, and just bought myself a 94 GT 5 speed. It's got power everything, black cloth interior, and it's got 101,000 miles. The car came with a full bbk stainless steel exhaust system, but it's got MAC mufflers. It's got a full BBK drag race suspension in the rear, Stock gears (3.27s?) are kinda sluggish, but it's still a blast to drive. There are a few problems though. Sometimes, when taking off from a dead stop, the car will chug and skip, then you can feel the motor kick in. I think it may be the coil pack, but figured I'd ask. So if any of you could throw in some info about that, I'd really appreciate it.
What I'm really here to ask is what are the cheapest, most effective mods that I can do to my car to wake it up a little bit. So far I've got this list: 3.90 gears, short throw shifter, 1.5 inch lowering springs, and then I was going to start saving my pennies for some trick flow heads and intake. If you guys could point me in the right direction, maybe tell me other cheaper mods you would recommend, I'd really appreciate it. Thanks in advance.
ID:	66800   Click image for larger version
Slow94GT is offline   Reply With Quote
Old 09-02-2012, 10:43 PM   #2
Re: 94 mustang gt help
Nice looking 94.
I'd bet the inexpensive mods have already been done, but check the "In the beginning" sticky thread to see if any were missed, then save those pennies for the HCI kit as it will make more of a difference than almost anything else you can do. The Trickflow HCI will increase your HP to around 350 at the flywheel.
Old 09-02-2012, 10:55 PM   #3
Slow94GT's Avatar
Originally Posted by Trojan Horse
Nice looking 94.
I'm guessing the HCI kit is Heads, Cam, and Intake?
Old 09-02-2012, 11:17 PM   #4
Yes, that way you get factory matched parts for the best results possible.
Old 09-02-2012, 11:23 PM   #5
Slow94GT's Avatar
Makes perfect sense. I'm assuming after this, I should have the car dyno tuned. Would a larger TB be recommended? I'm guessing a 70-73mm TB would be beneficial.
Old 09-02-2012, 11:38 PM   #6
Yes a 70MM would be recommended and work just fine with the HCI upgrade.
Note:
On the intake side it works best to have your intake tract funnel shaped to increase the flow and velocity of air into the intake.
Example 75MM MAF to 70MM TB.
Same thing on the exhaust side, but the other way with the smaller pipes at the engine leading to a progressively larger pipe out the back. This allows for exhaust gas flow and expansion and results in better scavenging of the cylinders for more power. There is an article link in the Useful Info thread with examples and information.
Old 09-02-2012, 11:42 PM   #7
Slow94GT's Avatar
Note:
Okay, so maybe 1 7/8 headers, 2.5 inch piping, and 3 inch tailpipes? The help is appreciated, great forum you've got here.
Old 09-03-2012, 12:06 AM   #8
Yes, that would be an improvement over the stock exhaust for sure.
You're welcome and thank you.
Old 09-03-2012, 02:46 PM   #9
93slowstang's Avatar
Welcome aboard, everything Trojan is saying is likely your best bet.
Old 09-03-2012, 05:44 PM   #10
Slow94GT's Avatar
Thanks! Yea, I think I'm going to save for the HCI kit.
Old 09-04-2012, 05:53 AM   #11
Adogg's Avatar
I also have a 94 mustang and that chug and skip your having happens to me but only when iam on the high then the car runs like crap when I get off the highway it has a hard time accelerating and it will chug everytime irelease the clutch any idea what this could be need to get it fixed?
Don't hate....... appreciate
Old 09-04-2012, 06:08 AM   #12
Slow94GT's Avatar
Yea, it happens a lot when it's cold. Or when the Rpms get dropped a little too low off of a start.
Old 09-04-2012, 07:25 AM   #13
Adogg's Avatar
Yeaa in the morin it will help and it will buck a little then will go way but when being on the highway for a little i can feel the car start to shake and it will run like crap and then when i get off the highway every time i wanna get going the just doesnt wanna move fast then after some city driing it goes away any ifdeas about that?
Old 09-04-2012, 01:06 PM   #14
Blown347's Avatar
I've been trying to figure this same thing out for a while. I have a 95 gt that chugs and drops off like that sometimes when I start driving and other times on the highway. Any ideas?
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-04-2012, 07:55 PM   #15
Rob94gt's Avatar
Is y'alls check engine light on when it does that
Rob94gt is offline   Reply With Quote
Old 09-04-2012, 07:57 PM   #16
Adogg's Avatar
Yeaa i no for me my engine light is coming on i could really use the help guys if anyone has any ides
Old 09-04-2012, 08:10 PM   #17
Rob94gt's Avatar
Well u could check your codes and that would atleast get u in thr right direction. If u don't know how look in the useful info in the stickes on this forum
Old 09-04-2012, 08:19 PM   #18
Adogg's Avatar
Yeaaa i looked it up and its a long complicated mess from what i saw
Old 09-04-2012, 10:10 PM   #19
Nevertheless you all need to check for CEL codes to point you in the right direction, otherwise you could spend a fortune just throwing parts at it. If you cannot figure out how to run the tests without a scanner, then you will need to buy one or have it scanned at an auto repair shop.
You have to have 3 things for an engine to run correctly, Air, fire & fuel.
You need to ensure that all 3 of those are operational and in the correct quantities where applicable.
So, start browsing the Useful Info thread and testing/cleaning components that could affect your engines in the ways you described.
06:52 PM
