94 Mustang Gt questions - Mustang Evolution
Old 09-02-2012, 11:47 PM   #1
kell97Gt's Avatar
So I'm back in Da saddle again I got a 94 Gt what clutch and flywheel would u guys recommend to replace my stock clutch and flywheel
kell97Gt is offline   Reply With Quote
Old 09-02-2012, 11:52 PM   #2
Slow94GT's Avatar
If its a stock 5.0, a stock replacement would be fine. I've got a 94 gt also, an I just did a clutch. For 150 bucks, i got a clutch, pressure plate, and a tob. And the clutch is strong. My car has no problem breaking the tires loose in 3rd gear.
If you want an aftermarket though, I'd recommend the king cobra clutch. Very strong, and not bad for a price.
Slow94GT is offline   Reply With Quote
Old 09-02-2012, 11:55 PM   #3
kell97Gt's Avatar
I took a glance at then do. I have to replacement the bell housing. Or it should be a derect fit
Old 09-03-2012, 12:02 AM   #4
Slow94GT's Avatar
Straight from fords website, they say that it will fit 94-95 gt's and cobras directly. No need to change the bell housing. Just make sure you have everything resurfaced so it's all in good working order. And break in that clutch too.
Old 09-03-2012, 12:14 AM   #5
kell97Gt's Avatar
Indeed. Thanks
Old 09-03-2012, 12:22 AM   #6
Slow94GT's Avatar
Indeed. Thanks
No problem!
Old 09-03-2012, 01:15 AM   #7
kell97Gt's Avatar
Aye. Question wat would u recommend I do to my car its all stock
Old 09-03-2012, 11:39 AM   #8
Slow94GT's Avatar
How's your budget? If its tight, then I'd say 3.73 gears, or 3.90 gears. Personally I recommend the 3.90s. GT40 heads an intake are among the cheaper heads and intakes, but you will notice a difference. The heads aren't as important, but the stock intakes on the 5.0s are very restrictive, one off of a cobra, explorer, or an aftermarket intake would be beneficial.
If your budget isnt too tight, Id go with the trick flow HCI kit. Comes with aluminum heads, cam, aluminum intake, valve covers, gaskets, etc.. Essentially every single thing you'll need comes in that kit. For us though, (94-95 mustangs) we will need an adapter for the throttle body, and a spacer for the intake. About 200 dollars more. The kit itself is 2600 dollars, but for about 3 grand, you go from a measly 225 horsepower 5.0, to a 350+ horsepower motor.
Old 09-03-2012, 12:06 PM   #9
kell97Gt's Avatar
Dam good recommendation
---------- Post added at 01:06 PM ---------- Previous post was at 12:56 PM ----------
Aye got a question
My stock springs thinkin bout cuting then I had some after market springs on my last mustang to bouncy
Old 09-03-2012, 01:45 PM   #10
Slow94GT's Avatar
Aye got a question
I dont quite understand what you're asking. If you cut your stock springs, then it's going to be way too soft and you'll bottom out.
Old 09-03-2012, 02:01 PM   #11
kell97Gt's Avatar
Really so bad idea
Old 09-03-2012, 02:44 PM   #12
Slow94GT's Avatar
Really so bad idea
Yes. If you want low, then you have to take the stiff.
Old 09-03-2012, 03:09 PM   #13
i disagree with the heads not being as important. as they are the most restrictive part of a 302 motor. the e7s really choke everything down. IMO they are the single most hp maker you can buy.
and for the springs being cut. the previous owner of my car cut the springs , and i have had no isssues.
Old 09-03-2012, 04:39 PM   #14
deadsp0t's Avatar
+ on all of this.
That's unimpressive
Old 09-03-2012, 05:25 PM   #15
kell97Gt's Avatar
Hows the ride round corners
Old 09-03-2012, 05:27 PM   #16
deadsp0t's Avatar
Cutting springs will be almost exclusively a looks mod. If you want tuned handling along with stance, some brand name springs would be your best bet.
That's unimpressive
Old 09-03-2012, 05:31 PM   #17
my car is pretty stiff. it corners pretty good. but i was more going for straight line. i have sub frame connectors, umi lift bars, kyb shocks and struts, and the drop is probably close to 2"s
i didnt cut these springs and would probably just buy new ones. but they are fine. and i have done them to vehicles in the past with good results. the most important thing is to make sure you cut them identical. you dont want your ride sitting out of level.
but my car seems to hook up really good. if your looking for high speed cornering i would look into that kind of specific suspension.
---------- Post added at 06:31 PM ---------- Previous post was at 06:29 PM ----------
exactly. i do think that the lower helps work well with the lift bars though. i think it increases the geometry change it was already doing with the relocation brackets. i do know was super pleased when i added the lift bars. but yeah i agree 100% with your statement.
*edit*
Old 09-03-2012, 05:36 PM   #18
deadsp0t's Avatar
Great minds!
That's unimpressive
Old 09-03-2012, 05:43 PM   #19
Slow94GT's Avatar
I was not aware how restrictive the heads were. I'm still new to the 5.0 scene. Thanks for the info
Old 09-03-2012, 05:44 PM   #20
deadsp0t's Avatar
A person breathing through a straw would be a fair comparison LOLOLOL
That's unimpressive
Old 09-03-2012, 05:50 PM   #21
The difference in aftermarket heads could be nearly 100+ hp. Or what dead said. Lol
Old 09-03-2012, 06:45 PM   #22
Slow94GT's Avatar
Wow that's horrible lol.
I just didn't think that they were that bad because, well, Im used to Mopars. I've got a Dodge Dakota, 5 speed, 318 stroked to a 402, making 450+ horse on the stock heads. My bad haha.
Old 10-07-2012, 01:02 AM   #23
kell97Gt's Avatar
O so my lower intake is jacked up wat intake at a junk yard will work will a old 5.0 grand marqoluis lower intake work any ideas
05:58 PM
