Running rich - Mustang Evolution
Old 09-03-2012, 11:39 AM   #1
91notchback's Avatar
Running rich
My car is running extremely rich and dying at stops on idle. When I first crank it, it has a very erratic idle if it idles at all. It's timed at 12btdc, I've went through the steps for setting base idle, checked my MAF, etc. I'm sure running out of ideas...
---------- Post added at 12:39 PM ---------- Previous post was at 12:36 PM ----------
Also, after I plug my spout connector in after setting timing, it advance a hell of a lot!
91notchback is offline   Reply With Quote
Old 09-03-2012, 02:44 PM   #2
93slowstang's Avatar
Sounds like a fuel problem, likely a bad fuel pressure regulator. 12* is your base timing and it should advance somewhere around 30* total with the spout connected so that's normal.
Old 09-03-2012, 03:19 PM   #3
Ok. That's about what my timing advances to. Is there a way to test my regulator so see if it's bad?
Old 09-03-2012, 03:22 PM   #4
Test fuel pressure before and after the reg. You should be around 38 with the vacuum removed at the rails. And I don't know the pressure before the reg but it should be slightly higher.
Old 09-04-2012, 08:29 AM   #5
I am getting an adjustable fpr this week. (was already in the market for one and a gauge.) BBK and some others are just too flashy under the hood as I like the dulled down look. Is Holley a good brand to go with on this part?
04:53 PM
