New motor - Mustang Evolution
Old 09-04-2012, 02:55 PM   #1
BLKKNGHT's Avatar
Region: Nebraska
New motor
Hello to all, I'm just starting out on this forum. I've been gathering information about what to do with my motor. I've recently bought GT -40 (non P) heads with the U/L intakes. Then I read that if I boar the motor .400 over, they would 'slow' it down. Would a 331 be ok with this set up? Or should I leave it stock?
BLKKNGHT is offline   Reply With Quote
Old 09-04-2012, 03:11 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
That's ridiculous!!! Bore the motor .030 to start with if you can.. But the gt40's will work fine we've had them on .060 motors
90GTNovi2000 is offline   Reply With Quote
Old 09-04-2012, 03:22 PM   #3
BLKKNGHT's Avatar
Region: Nebraska
The block is still bone stock, down to the original exhaust.
I found a 302 block thats been boared, honed and has new freeze plugs for $300 on CL, should I jump on it?
Old 09-04-2012, 03:44 PM   #4
Forum Car Trader
That's not a bad price does it have the crank and rods and pistons? Or just the block? If you already have an engine machine work isn't very expensive
Old 09-04-2012, 05:17 PM   #5
BLKKNGHT's Avatar
Region: Nebraska
Ok, so I contacted the guy with the block on CL, he says is just the block, but he had a stock crank if I wanted it. Then he said he wouldn't run a stock crank.
Old 09-04-2012, 05:39 PM   #6
Forum Car Trader
If I wasn't on a budget I wouldn't run a stock crank either.. But the crank will out last the block if built right
Old 09-04-2012, 05:40 PM   #7
i would wait. it would be an ok buy in a pinch. but i can get a complete running motor for that right now.. just saying.
Old 09-04-2012, 05:45 PM   #8
BLKKNGHT's Avatar
Region: Nebraska
I have seen rebuild kits that come with the correct cranks. I offered $250 for the block, but havent heard back yet.
Old 09-04-2012, 06:28 PM   #9
deadsp0t's Avatar
Any bore past .030 you run a serious risk of over heating on a stock type 302 block.
That's unimpressive
Old 09-04-2012, 11:31 PM   #10
Re: New motor
Make sure the block is an H.O. roller block or you will be stuck with extra cost converting it.
Old 09-05-2012, 05:44 AM   #11
BLKKNGHT's Avatar
Region: Nebraska
Very good point trojan, I found a website that tells you the everything about the casting numbers. I'm going to use that to be absolutely sure what kind of block it is.
Old 09-05-2012, 07:44 AM   #12
Re: New motor
Good idea.
I know how it is to run across what seems to be a good deal, make the purchase in a hurry and get burned when it doesn't turn out to be what you really wanted.
Old 09-08-2012, 07:53 PM   #13
BLKKNGHT's Avatar
Region: Nebraska
Got the block today, its from a 91, according to the site I seen. $275. Its even been notched for a 347. The 331 idea is in the rearview now.
Old 09-08-2012, 09:07 PM   #14
93slowstang's Avatar
I would personally opt for the 331 over a 347 if it's going to be a daily driver. Reason being is there is a lot of pressure on one side of the cylinder walls do to the long stroke of the 347. The 331 Hp isn't far under a 347 but it will last longer.
Old 09-08-2012, 09:13 PM   #15
deadsp0t's Avatar
advise!
That's unimpressive
Old 09-08-2012, 11:57 PM   #16
BLKKNGHT's Avatar
Region: Nebraska
Thank you for the reminder! I knew there was a reason for doing the 331 over the 347. I forgot about the longer stroke. Ok then, 331 it is. Plus it will be slightly cheaper to build.
Old 09-09-2012, 06:18 PM   #17
2300turboford's Avatar
Get a on3 turbo kit
Old 09-09-2012, 07:14 PM   #18
BLKKNGHT's Avatar
Region: Nebraska
I wish!!! now I'm trying to figure out what type of pistons I should use. Flat, dome, notched...what would be best?
08:13 PM
