I have no idea - Mustang Evolution
Old 09-04-2012, 06:13 PM   #1
94GTpony's Avatar
I have no idea
So a week or so ago I posted a thread about rattleing in my pass rear tire. I checked to see If it might be the sway bar linkage but I didn't see anything wrong bc I assume you could
See that if it was. Now it not really rattles when at idol and then goes away when driving. I have no idea what it is.
94GTpony is offline   Reply With Quote
Old 09-04-2012, 06:20 PM   #2
deadsp0t's Avatar
It may be a broken exhaust hanger.
That's unimpressive
Old 09-04-2012, 06:21 PM   #3
i was just thinking that also. its kinda hard for us to pinpoint a noise without hearing it.
Old 09-04-2012, 06:23 PM   #4
94GTpony's Avatar
But could you here that just through the right rear?
---------- Post added at 07:23 PM ---------- Previous post was at 07:21 PM ----------
I understand. Yeah it just sounds like the whole damn spring it's broken
Old 09-04-2012, 06:24 PM   #5
deadsp0t's Avatar
Yes. Easy was to check is to grab the pipe and try to shake both sides. I had a similar issue with a ball and socket joint in my pipes and bolt(s) had backed out and started rattling.
That's unimpressive
Old 09-04-2012, 06:26 PM   #6
noises are tricky and have a tendancy to echoe. a simple check of grabbing the exhaust( passenger side first) and seeing if you can move it. then check all hangers. maybe putting the car on jackstands, in neautral and rotate the tire? idk man im just throwing bones.
Old 09-04-2012, 06:28 PM   #7
94GTpony's Avatar
Thanks for the advice man. I'll check it out and let you know
---------- Post added at 07:28 PM ---------- Previous post was at 07:27 PM ----------
Thanks yeah I understand it's freakinh annoying
Old 09-04-2012, 06:29 PM   #8
deadsp0t's Avatar
That's unimpressive
Old 09-04-2012, 07:09 PM   #9
94GTpony's Avatar
I shook the right side exhaust and it did make the same exact noise that it makes when at idol. And the driver side didn't make any noise.
Old 09-04-2012, 07:24 PM   #10
Awsome man!
Old 09-05-2012, 07:35 AM   #11
deadsp0t's Avatar
Agreed, probably best to go by an exhaust shop, doubt it would cost much at all.
That's unimpressive
Old 09-05-2012, 06:09 PM   #12
94GTpony's Avatar
So today I was looking at the exhaust and started moving it and it was twisting where the flow masters connect to the cats. One side is straight and the other is cocked side ways.
Old 09-05-2012, 06:17 PM   #13
Mustang936's Avatar
Yeah that sounds like a loose exhaust, I had the some rattling because I had loose exhaust
Mustang936 is offline   Reply With Quote
Old 09-06-2012, 08:11 PM   #14
94GTpony's Avatar
Would that cause it to sound like it has a leak also.?
Old 09-06-2012, 08:12 PM   #15
a leak.
sounds like you just meed to repair your exhaust.
Old 09-06-2012, 08:16 PM   #16
94GTpony's Avatar
Thanks man
Old 09-07-2012, 07:39 AM   #17
deadsp0t's Avatar
Save time and frustration and take it somewhere to get it buttoned up.
That's unimpressive
04:42 AM
