car won't start - Mustang Evolution
Old 09-05-2012, 04:53 PM   #1
Jettin Stang's Avatar
car won't start
I replaced the cap n rotor n the wires w msd products..they are in the right firing order.
I did a smog delete also n removed the egr valve also so idk if removing the egr valve would cause it to not start or not
Jettin Stang is offline   Reply With Quote
Old 09-05-2012, 05:51 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
Spark fuel and timing.. Find out if your getting spark? Check your regulator for fuel pressure.. Did you use the H.O firing order? Are your plugs gapped correctly..
90GTNovi2000 is offline   Reply With Quote
Old 09-05-2012, 05:54 PM   #3
Idk...idk there was differ firing orders..u have to gap them?
Old 09-05-2012, 05:58 PM   #4
This is the diagram that I found
Old 09-05-2012, 06:07 PM   #5
Thats the correct firing order. Double check your wires one at a time in order. Starting with 1 then 3 then 7 and so on.
keaton5.0 is offline   Reply With Quote
Old 09-05-2012, 06:27 PM   #6
I haven't changed the plugs yet they won't be in until tomorrow but how do I gap them?
---------- Post added at 08:27 PM ---------- Previous post was at 08:26 PM ----------
So removing the egr won't keep it from starting?
Old 09-05-2012, 06:29 PM   #7
get a spark plug gapper from autozone. they are like .99$ it will be shaped like a wedge. just make sure they plugs are around .050-.054 you can use the wedge to open them up if needed. if they are big just lightly it in on a piece of wood to make smaller.
Old 09-05-2012, 06:33 PM   #8
fomoco4life's Avatar
Get a pluggap tool. Plugs usually will come overgapped, tap on ground til they close a little, then slide the tool in til u reach desired gap. I go a little over (.02-.05) more than spec. Extra spark helps imo
Old 09-05-2012, 06:42 PM   #9
Ok thanks...when we were testing the coil both wires going to it were positive are they suppose to be?
Old 09-05-2012, 06:44 PM   #10
93slowstang's Avatar
That extra gap can cause a weaker spark which is not good.
Old 09-05-2012, 06:54 PM   #11
+1 and has also been know to cause electrical/charging issues do to over working the ignition system.
Old 09-05-2012, 09:33 PM   #12
Hmmm.good2 know, need to pass this on to the trackguy that informed me years ago to overgap. (Tho ive never had any issues with a bit of overgap)
Old 09-06-2012, 04:34 AM   #13
If it doesn't affect you then I wouldnt worry about it. In most cases it probably wouldnt. But just something to be aware of. And most racers that go for the bigger gaps are running full msd/aftermarket ignition systems that help strengthen the spark, which allows to shoot the bigger gap.
Old 09-06-2012, 05:08 AM   #14
Re: car won't start
No, the wire on the + side is 12 volts, the wire on the - side goes to the distributor.
Old 09-06-2012, 05:27 AM   #15
Hey trojan would removing the egr keep it from starting?
Old 09-06-2012, 02:06 PM   #16
Removing it won't affect it unless you didn't use a block off plate on the egr spacer. The only thing that should happen after removal is a CEL and there is a fix for that.
Old 09-06-2012, 03:34 PM   #17
Ok yea I blocked it off...I don't have a cel lol
---------- Post added at 05:34 PM ---------- Previous post was at 05:17 PM ----------
WE think it's not getting any fuel we can get it to start and run for a sec w starting fluid
Old 09-06-2012, 03:35 PM   #18
Sounds like you need to get a fuel pressure gauge and check it. Can you hear your pump prime?
Old 09-06-2012, 04:08 PM   #19
Idk I had just woke up when we ****ed w it said **** it n stated working on something else I'll check in the morning
---------- Post added at 06:08 PM ---------- Previous post was at 05:40 PM ----------
how do I check it with the gauge?
Old 09-06-2012, 04:12 PM   #20
Hook it to the schrader valve on your fuel line and have someone turn the car over.
Old 09-06-2012, 08:32 PM   #21
If it's the fuel pump how long n much of a pain in the *** is it
Old 09-06-2012, 10:01 PM   #22
Took me roughly an hour taking my time. Wasn't really that difficult, just awkward getting the tank out and back in.
Old 09-06-2012, 11:03 PM   #23
good cuz I only got a day to get it running hopefully auto store has one in stock if that's what it is
Old 09-07-2012, 06:01 AM   #24
Just don't get a cheaply autozone special if you can help it. Factory replacement or walbro will do fine.
Old 09-07-2012, 06:10 AM   #25
I get my stuff from O'Reilly wasn't planning on getting a cheap one
Old 09-07-2012, 08:05 AM   #26
Just making sure. I would hate for it to go out on you in 6 months
Old 09-07-2012, 08:10 AM   #27
Main thing I'm worried bout is getting it running for the show tomorrow
Old 09-07-2012, 09:29 AM   #28
We also removed a relay that had a wire from the egr would that effect it?
Old 09-07-2012, 10:18 AM   #29
Well we found the problem the fuel pump isn't turning on
Old 09-07-2012, 02:21 PM   #30
I would check the inertia switch and the relay.
Old 09-07-2012, 02:56 PM   #31
Both gd
Old 09-07-2012, 03:01 PM   #32
Both gd
Hope you have less than 1/4 tank. A wobbling gas tank is no fun trying to get in and out.
Old 09-07-2012, 03:10 PM   #33
We got the pump to turn on
Old 09-07-2012, 03:13 PM   #34
Jumped it out?
Old 09-07-2012, 03:14 PM   #35
how did you do that?
04:18 PM
