Gas - Mustang Evolution
Old 09-08-2012, 04:46 PM   #1
94GTpony's Avatar
Gas
Every since I did my tune up oil, spark plugs my gas has been sucking down any suggestions ?
---------- Post added at 05:46 PM ---------- Previous post was at 05:45 PM ----------
And my check engine light has been coming on and off
94GTpony is offline   Reply With Quote
Old 09-08-2012, 04:48 PM   #2
Mattz400's Avatar
Well keep your foot out of it. Personally I can't seem to do it but that's my guess. Other than a change in driving style I can't imagine a tune up would decrease your mileage, last I knew that was supposed to help it.
---------- Post added at 05:48 PM ---------- Previous post was at 05:47 PM ----------
Do you have the proper amount of oil in?
Notta 66
Mattz400 is offline   Reply With Quote
Old 09-08-2012, 06:00 PM   #3
94GTpony's Avatar
I'm pretty sure that it called for 5 qts right?
Old 09-08-2012, 08:09 PM   #4
Mattz400's Avatar
That sounds right if you changed oil and filter.
Notta 66
Old 09-08-2012, 11:23 PM   #5
Re: Gas
Run the codes or have it scanned, you may have a malfunctioning O2 sensor or something else causing the excessive fuel usage.
Old 09-09-2012, 08:31 AM   #6
94GTpony's Avatar
HAve it scanned meaning on. A diagnostics tester.?
Old 09-09-2012, 01:05 PM   #7
black94stallion's Avatar
Can 94-95 be scanned? I took mine to autozone and it would hook up but wouldn't read he told me that it was too old... Where can I get mine scanned at?
black94stallion is offline   Reply With Quote
Old 09-09-2012, 01:25 PM   #8
you need an ob1 scanner. you can pick them up for around 25$. or there is a link in the useful stickies thread for how to scan the codes without a scanner.
Old 09-09-2012, 07:05 PM   #9
Re: Gas
A diagnostic code scanner, see dreamstang's post above.
Old 09-09-2012, 07:43 PM   #10
94GTpony's Avatar
Thanks guys for all your help.
Old 09-09-2012, 08:14 PM   #11
Re: Gas
You're welcome and good luck with your project.
Old 09-10-2012, 06:42 AM   #12
Oreileys auto parts has these that they lend out. I'm positive because I've used it on multiple occasions.
JayKranz is offline   Reply With Quote
Old 09-10-2012, 07:50 AM   #13
Alright, thanks man
Old 09-10-2012, 08:19 AM   #14
87fox's Avatar
Oriellys will. I've had my cousins 94 gt tested there twice.
87fox is offline   Reply With Quote
Old 09-10-2012, 02:46 PM   #15
Snap on sells one tell u everything voltage of sensors o2 reading
---------- Post added at 05:16 PM ---------- Previous post was at 05:05 PM ----------
Check this out does allot more then a Code reader http://buy1.snapon.com/catalog/item....re&dir=catalog
tbonestang is offline   Reply With Quote
08:23 PM
